[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.transform/trans_digit.c |no clones | 0 monsters | 1 warnings
Mon Oct 15 06:42:39 EDT 2007
Hello markus,
ANALYSIS
vector/v.transform/trans_digit.c functions
transform_digit_file (Begins at: 31 Ends at: 151)
Complexity:   |      18 |     * |         |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |      30 |       |      OK |
LOC:          |     121 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
