[GRASS-QA] GRASS QA: robertoa | ./grass6/vector/lidar/v.lidar.correction/correction.c |no clones | 1 monsters | 0 warnings
Thu Oct 18 10:29:25 EDT 2007
Hello robertoa,
ANALYSIS
vector/lidar/v.lidar.correction/correction.c functions
P_Sparse_Correction (Begins at: 11 Ends at: 155)
Complexity:   |      25 |     * |         |
ParamNBR:     |      19 |   *** | MONSTER |
CalledNBR:    |      62 |    ** | Warning |
LOC:          |     145 |     * |         |
1 metric are OUT OF RANGE!
correction (Begins at: 158 Ends at: 173)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       2 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
Select_Correction (Begins at: 175 Ends at: 204)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
Insert_Correction (Begins at: 206 Ends at: 218)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
UpDate_Correction (Begins at: 220 Ends at: 230)
CalledNBR:    |       4 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
P_Read_Vector_Correction (Begins at: 233 Ends at: 297)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      65 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-18 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
