[GRASS-QA] GRASS QA: robertoa | ./grass6/vector/lidar/v.lidar.edgedetection/main.c |no clones | 2 monsters | 0 warnings
Fri Oct 19 10:50:15 EDT 2007
Hello robertoa,
ANALYSIS
vector/lidar/v.lidar.edgedetection/main.c functions
main (Begins at: 44 Ends at: 354)
Complexity:   |      22 |     * |         |
CalledNBR:    |     138 |   *** | MONSTER |
LOC:          |     311 |   *** | MONSTER |
2 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-19 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
