[GRASS-QA] GRASS QA: glynn | ./grass6/lib/stats/c_reg.c |2 clones ( c_reg.c )| 0 monsters | 0 warnings
Tue Oct 23 14:43:23 EDT 2007
Hello glynn,
ANALYSIS
lib/stats/c_reg.c functions
regression (Begins at: 3 Ends at: 48)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
c_reg_m (Begins at: 50 Ends at: 53)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
c_reg_c (Begins at: 55 Ends at: 58)
LOC:          |       4 |       |      OK |
metrics are OK
regression_w (Begins at: 60 Ends at: 105)
LOC:          |      46 |       |      OK |
metrics are OK
w_reg_m (Begins at: 107 Ends at: 110)
LOC:          |       4 |       |      OK |
metrics are OK
w_reg_c (Begins at: 112 Ends at: 115)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  regression_w  regression
In lib/stats/c_reg.c clones of  regression_w are:
	lib/stats/c_reg.c  regression
In lib/stats/c_reg.c clones of  regression are:
	lib/stats/c_reg.c  regression_w
Threshold GRASS6 key metrics values at 2007-10-23 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
