[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.los/segment.c |no clones | 1 monsters | 0 warnings
Wed Oct 31 02:50:21 EDT 2007
Hello hamish,
ANALYSIS
raster/r.los/segment.c functions
segment (Begins at: 17 Ends at: 83)
Complexity:   |       5 |       |      OK |
ParamNBR:     |      15 |   *** | MONSTER |
CalledNBR:    |       2 |       |      OK |
LOC:          |      67 |       |      OK |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-31 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
