[GRASS-QA] GRASS QA: martinl | ./grass6/db/base/columns.c |no clones | 0 monsters | 0 warnings
Sat Sep 8 15:01:40 EDT 2007
Hello martinl,
ANALYSIS
db/base/columns.c functions
main (Begins at: 28 Ends at: 62)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
parse_command_line (Begins at: 65 Ends at: 97)
CalledNBR:    |      12 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-09-08 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
