[GRASS-QA] GRASS QA: carlos | ./grass6/vector/v.to.db/update.c |no clones | 1 monsters | 0 warnings
Wed Sep 19 17:34:46 EDT 2007
Hello carlos,
ANALYSIS
vector/v.to.db/update.c functions
update (Begins at: 10 Ends at: 204)
Complexity:   |      51 |   *** | MONSTER |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      49 |     * |         |
LOC:          |     195 |     * |         |
1 metric are OUT OF RANGE!
srch (Begins at: 206 Ends at: 214)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-09-19 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
