[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.mkgrid/write_grid.c |no clones | 0 monsters | 0 warnings
Wed Sep 26 03:05:37 EDT 2007
Hello martinl,
ANALYSIS
vector/v.mkgrid/write_grid.c functions
write_grid (Begins at: 8 Ends at: 111)
Complexity:   |       2 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |     104 |       |      OK |
metrics are OK
write_vect (Begins at: 119 Ends at: 145)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       4 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-09-26 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
