[GRASS-QA] GRASS QA: martinl |build.c build_nat.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Dec 11 02:41:57 EST 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/vector/Vlib/build.c
          Function
format(Begins at: 29, Ends at:33)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       0 |       |           OK |         0 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       5 |       |           OK |         5 |
Conclusion:   | this function is a            OK           |
metrics are OK
prnmsg(Begins at: 48, Ends at:62)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      15 |       |           OK |        15 |
metrics are OK
Vect_build(Begins at: 73, Ends at:76)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
Vect_build_partial(Begins at: 128, Ends at:248)
Complexity:   |      20 |    ** | BABY-MONSTER |        20 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      46 |   *** |      MONSTER |        46 |
LOC:          |     121 |    ** | BABY-MONSTER |       121 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Vect_get_built(Begins at: 86, Ends at:89)
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
metrics are OK
Vect_save_spatial_index(Begins at: 408, Ends at:440)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |      14 |     * |      WARNING |        14 |
LOC:          |      33 |       |           OK |        33 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Vect_save_topo(Begins at: 257, Ends at:289)
Vect_spatial_index_dump(Begins at: 451, Ends at:462)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      12 |       |           OK |        12 |
metrics are OK
Vect_topo_dump(Begins at: 300, Ends at:398)
Complexity:   |      13 |    ** | BABY-MONSTER |        13 |
CalledNBR:    |      21 |     * |      WARNING |        21 |
LOC:          |      99 |    ** | BABY-MONSTER |        99 |
Conclusion:   | this function is a  BABY-MONSTER           |
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/lib/vector/Vlib/build_nat.c
          Function
Vect_attach_centroids(Begins at: 332, Ends at:413)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      82 |     * |      WARNING |        82 |
 at least 2 values are close to an outlier please consider revising code!
Vect_attach_isle(Begins at: 261, Ends at:288)
LOC:          |      28 |       |           OK |        28 |
metrics are OK
Vect_attach_isles(Begins at: 298, Ends at:322)
LOC:          |      25 |       |           OK |        25 |
metrics are OK
Vect_build_line_area(Begins at: 40, Ends at:118)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |      26 |    ** | BABY-MONSTER |        26 |
LOC:          |      79 |     * |      WARNING |        79 |
Vect_build_nat(Begins at: 425, Ends at:677)
Complexity:   |      42 |   *** |      MONSTER |        42 |
CalledNBR:    |      59 |   *** |      MONSTER |        59 |
LOC:          |     253 |   *** |      MONSTER |       253 |
Vect_isle_find_area(Begins at: 129, Ends at:251)
Complexity:   |      11 |     * |      WARNING |        11 |
CalledNBR:    |      27 |    ** | BABY-MONSTER |        27 |
LOC:          |     123 |    ** | BABY-MONSTER |       123 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 03:08:04 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
