[GRASS-QA] GRASS QA: glynn |gisdefs.h env.c get_window.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Dec 11 03:18:55 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/include/gisdefs.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/lib/gis/env.c
          Function
get_env(Begins at: 182, Ends at:193)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      12 |       |           OK |        12 |
Conclusion:   | this function is a            OK           |
metrics are OK
G_getenv(Begins at: 267, Ends at:276)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
G_getenv2(Begins at: 293, Ends at:302)
metrics are OK
G_get_gisrc_mode(Begins at: 71, Ends at:74)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
G_setenv(Begins at: 352, Ends at:358)
LOC:          |       7 |       |           OK |         7 |
metrics are OK
G_setenv2(Begins at: 372, Ends at:378)
ParamNBR:     |       3 |     * |      WARNING |         3 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
G_set_gisrc_mode(Begins at: 59, Ends at:62)
metrics are OK
G_unsetenv(Begins at: 420, Ends at:427)
LOC:          |       8 |       |           OK |         8 |
metrics are OK
G_unsetenv2(Begins at: 438, Ends at:445)
metrics are OK
G__create_alt_env(Begins at: 537, Ends at:552)
LOC:          |      16 |       |           OK |        16 |
metrics are OK
G__env_name(Begins at: 476, Ends at:486)
Complexity:   |       4 |       |           OK |         4 |
LOC:          |      11 |       |           OK |        11 |
metrics are OK
G__getenv(Begins at: 312, Ends at:320)
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |       9 |       |           OK |         9 |
metrics are OK
G__getenv2(Begins at: 331, Ends at:339)
metrics are OK
G__get_gisrc_file(Begins at: 525, Ends at:528)
metrics are OK
G__read_env(Begins at: 495, Ends at:500)
LOC:          |       6 |       |           OK |         6 |
metrics are OK
G__setenv(Begins at: 388, Ends at:393)
CalledNBR:    |       2 |       |           OK |         2 |
metrics are OK
G__setenv2(Begins at: 404, Ends at:409)
G__set_gisrc_file(Begins at: 509, Ends at:516)
metrics are OK
G__switch_env(Begins at: 561, Ends at:576)
metrics are OK
G__write_env(Begins at: 454, Ends at:460)
metrics are OK
open_env(Begins at: 233, Ends at:256)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      24 |       |           OK |        24 |
metrics are OK
read_env(Begins at: 76, Ends at:110)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      35 |       |           OK |        35 |
set_env(Begins at: 112, Ends at:165)
Complexity:   |       8 |     * |      WARNING |         8 |
CalledNBR:    |      13 |     * |      WARNING |        13 |
LOC:          |      54 |     * |      WARNING |        54 |
 at least 4 values are close to an outlier please consider revising code!
unset_env(Begins at: 167, Ends at:180)
LOC:          |      14 |       |           OK |        14 |
metrics are OK
write_env(Begins at: 195, Ends at:207)
LOC:          |      13 |       |           OK |        13 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/lib/gis/get_window.c
          Function
G_get_default_window(Begins at: 115, Ends at:124)
metrics are OK
G_get_window(Begins at: 47, Ends at:100)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |      19 |     * |      WARNING |        19 |
 at least 3 values are close to an outlier please consider revising code!
G__get_window(Begins at: 126, Ends at:156)
ParamNBR:     |       4 |     * |      WARNING |         4 |
LOC:          |      31 |       |           OK |        31 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 03:45:03 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
