[GRASS-QA] GRASS QA: glynn |printwindow.c gisdefs.h proj3.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Dec 11 04:55:55 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/general/g.region/printwindow.c
          Function
print_window(Begins at: 8, Ends at:653)
              |          New Metrics           |Old Metrics|
Complexity:   |      71 |   *** |      MONSTER |        71 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     232 |   *** |      MONSTER |       232 |
LOC:          |     646 |   *** |      MONSTER |       646 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/include/gisdefs.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/lib/gis/proj3.c
          Function
equal(Begins at: 190, Ends at:200)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      11 |       |           OK |        11 |
Conclusion:   | this function is a            OK           |
metrics are OK
G_database_datum_name(Begins at: 133, Ends at:151)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      19 |       |           OK |        19 |
metrics are OK
G_database_ellipse_name(Begins at: 162, Ends at:175)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      14 |       |           OK |        14 |
metrics are OK
G_database_projection_name(Begins at: 51, Ends at:66)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      16 |       |           OK |        16 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
G_database_units_to_meters_factor(Begins at: 80, Ends at:111)
LOC:          |      32 |       |           OK |        32 |
metrics are OK
G_database_unit_name(Begins at: 21, Ends at:37)
LOC:          |      17 |       |           OK |        17 |
lookup(Begins at: 177, Ends at:188)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
LOC:          |      12 |       |           OK |        12 |
lower(Begins at: 202, Ends at:207)
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 05:22:03 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
