[GRASS-QA] GRASS QA: martinl |main.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Dec 11 10:00:44 EST 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/vector/v.distance/main.c
          Function
cmp_exist(Begins at: 1189, Ends at:1199)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      11 |       |           OK |        11 |
Conclusion:   | this function is a            OK           |
metrics are OK
cmp_near(Begins at: 1156, Ends at:1166)
metrics are OK
cmp_near_to(Begins at: 1168, Ends at:1186)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      19 |       |           OK |        19 |
metrics are OK
main(Begins at: 72, Ends at:1153)
Complexity:   |     174 |   *** |      MONSTER |       174 |
CalledNBR:    |     340 |   *** |      MONSTER |       340 |
LOC:          |    1082 |   *** |      MONSTER |      1082 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
print_upload(Begins at: 1204, Ends at:1277)
Complexity:   |      21 |   *** |      MONSTER |        21 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      17 |     * |      WARNING |        17 |
LOC:          |      74 |     * |      WARNING |        74 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Thu Dec 11 10:26:55 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
