[GRASS-QA] GRASS QA: neteler |main.c main.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Nov 12 00:58:09 EST 2008
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/raster/r.drain/main.c
          Class
point(Begins at: 60, Ends at:66)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Function
drain(Begins at: 460, Ends at:517)
              |          New Metrics           |Old Metrics|
Complexity:   |       8 |     * |      WARNING |           |
ParamNBR:     |       4 |     * |      WARNING |           |
CalledNBR:    |       8 |       |           OK |           |
LOC:          |      58 |     * |      WARNING |           |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
main(Begins at: 68, Ends at:458)
Complexity:   |      41 |   *** |      MONSTER |           |
ParamNBR:     |       8 |    ** | BABY-MONSTER |           |
CalledNBR:    |     133 |   *** |      MONSTER |           |
LOC:          |     391 |   *** |      MONSTER |           |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :grass/branches/develbranch_6/raster/r.info/main.c
          Function
compose_line(Begins at: 417, Ends at:431)
Complexity:   |       2 |       |           OK |           |
ParamNBR:     |       3 |     * |      WARNING |           |
CalledNBR:    |       7 |       |           OK |           |
LOC:          |      15 |       |           OK |           |
 at least 1 values are close to an outlier please consider revising code!
format_double(Begins at: 410, Ends at:414)
Complexity:   |       1 |       |           OK |           |
ParamNBR:     |       2 |       |           OK |           |
CalledNBR:    |       2 |       |           OK |           |
LOC:          |       5 |       |           OK |           |
Conclusion:   | this function is a            OK           |
metrics are OK
main(Begins at: 39, Ends at:407)
Complexity:   |      45 |   *** |      MONSTER |           |
CalledNBR:    |     128 |   *** |      MONSTER |           |
LOC:          |     369 |   *** |      MONSTER |           |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Wed Nov 12 01:18:00 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
