[GRASS-QA] GRASS QA: martinl |plus_line.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Oct 2 11:34:48 EDT 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/vector/diglib/plus_line.c
          Function
dig_add_line(Begins at: 31, Ends at:131)
              |          New Metrics           |Old Metrics|
Complexity:   |      16 |    ** | BABY-MONSTER |        16 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      22 |     * |      WARNING |        22 |
LOC:          |     101 |    ** | BABY-MONSTER |       101 |
Conclusion:   | this function is a  BABY-MONSTER           |
metrics are OK
dig_del_line(Begins at: 148, Ends at:213)
Complexity:   |      12 |     * |      WARNING |        12 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      10 |     * |      WARNING |        10 |
LOC:          |      66 |     * |      WARNING |        66 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
dig_line_get_area(Begins at: 226, Ends at:246)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      21 |       |           OK |        21 |
metrics are OK
dig_line_get_box(Begins at: 308, Ends at:322)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      15 |       |           OK |        15 |
metrics are OK
dig_line_set_area(Begins at: 258, Ends at:272)
metrics are OK
dig_line_set_box(Begins at: 283, Ends at:297)
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold GRASS6 key metrics values at Thu Oct 02 11:46:00 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
