[GRASS-QA] GRASS QA: glynn |parser.c | 2 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Oct 2 12:11:40 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/gis/parser.c
          Class
Item(Begins at: 109, Ends at:114)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Function
check_an_opt(Begins at: 2201, Ends at:2243)
              |          New Metrics           |Old Metrics|
Complexity:   |      10 |     * |      WARNING |        10 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      13 |     * |      WARNING |        13 |
LOC:          |      43 |     * |      WARNING |        43 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
check_double(Begins at: 2309, Ends at:2345)
Complexity:   |      14 |    ** | BABY-MONSTER |        14 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      37 |       |           OK |        37 |
Conclusion:   | this function is a  BABY-MONSTER           |
metrics are OK
check_int(Begins at: 2245, Ends at:2281)
metrics are OK
check_multiple_opts(Begins at: 2457, Ends at:2492)
Complexity:   |       8 |     * |      WARNING |         8 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      36 |       |           OK |        36 |
metrics are OK
check_opts(Begins at: 2165, Ends at:2199)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      35 |       |           OK |        35 |
metrics are OK
check_overwrite(Begins at: 2495, Ends at:2560)
Complexity:   |      12 |     * |      WARNING |        12 |
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |      66 |     * |      WARNING |        66 |
metrics are OK
check_required(Begins at: 2373, Ends at:2395)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      23 |       |           OK |        23 |
Conclusion:   | this function is a            OK           |
metrics are OK
check_string(Begins at: 2347, Ends at:2371)
Complexity:   |       9 |     * |      WARNING |         9 |
LOC:          |      25 |       |           OK |        25 |
metrics are OK
contains(Begins at: 2083, Ends at:2091)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       9 |       |           OK |         9 |
metrics are OK
generate_tcl(Begins at: 1815, Ends at:1913)
CalledNBR:    |      34 |    ** | BABY-MONSTER |        34 |
LOC:          |      99 |    ** | BABY-MONSTER |        99 |
metrics are OK
G_define_flag(Begins at: 176, Ends at:213)
Complexity:   |       3 |     * |      WARNING |         3 |
CalledNBR:    |       4 |     * |      WARNING |         4 |
LOC:          |      38 |     * |      WARNING |        38 |
metrics are OK
G_define_module(Begins at: 649, Ends at:662)
Complexity:   |       1 |       |           OK |         1 |
LOC:          |      14 |       |           OK |        14 |
metrics are OK
G_define_option(Begins at: 232, Ends at:283)
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      52 |       |           OK |        52 |
metrics are OK
G_define_standard_option(Begins at: 312, Ends at:640)
Complexity:   |      38 |       |           OK |        38 |
CalledNBR:    |      43 |       |           OK |        43 |
LOC:          |     329 |     * |      WARNING |       329 |
metrics are OK
G_disable_interactive(Begins at: 155, Ends at:160)
Complexity:   |       1 |   *** |      MONSTER |         1 |
CalledNBR:    |       0 |   *** |      MONSTER |         0 |
LOC:          |       6 |   *** |      MONSTER |         6 |
Conclusion:   | this function is a       MONSTER           |
metrics are OK
G_gui(Begins at: 1973, Ends at:1988)
LOC:          |      16 |       |           OK |        16 |
metrics are OK
G_gui_tcltk(Begins at: 1918, Ends at:1947)
Complexity:   |       6 |       |           OK |         6 |
CalledNBR:    |      12 |       |           OK |        12 |
LOC:          |      30 |       |           OK |        30 |
metrics are OK
G_gui_wx(Begins at: 1952, Ends at:1964)
CalledNBR:    |       6 |     * |      WARNING |         6 |
LOC:          |      13 |       |           OK |        13 |
metrics are OK
G_parser(Begins at: 701, Ends at:955)
Complexity:   |      41 |       |           OK |        41 |
CalledNBR:    |      83 |       |           OK |        83 |
LOC:          |     255 |       |           OK |       255 |
metrics are OK
G_recreate_command(Begins at: 2600, Ends at:2699)
Complexity:   |      14 |   *** |      MONSTER |        14 |
CalledNBR:    |      26 |   *** |      MONSTER |        26 |
LOC:          |     100 |   *** |      MONSTER |       100 |
metrics are OK
G_script(Begins at: 1696, Ends at:1808)
Complexity:   |      24 |    ** | BABY-MONSTER |        24 |
CalledNBR:    |      46 |    ** | BABY-MONSTER |        46 |
LOC:          |     113 |    ** | BABY-MONSTER |       113 |
metrics are OK
G_tcltk(Begins at: 1993, Ends at:2001)
Complexity:   |       3 |   *** |      MONSTER |         3 |
CalledNBR:    |       2 |   *** |      MONSTER |         2 |
LOC:          |       9 |    ** | BABY-MONSTER |         9 |
metrics are OK
G_usage(Begins at: 1008, Ends at:1179)
Complexity:   |      34 |       |           OK |        34 |
CalledNBR:    |      53 |       |           OK |        53 |
LOC:          |     172 |       |           OK |       172 |
metrics are OK
G_usage_html(Begins at: 1472, Ends at:1691)
Complexity:   |      42 |   *** |      MONSTER |        42 |
CalledNBR:    |      85 |   *** |      MONSTER |        85 |
LOC:          |     220 |   *** |      MONSTER |       220 |
metrics are OK
G_usage_xml(Begins at: 1234, Ends at:1467)
Complexity:   |      31 |   *** |      MONSTER |        31 |
CalledNBR:    |      87 |   *** |      MONSTER |        87 |
LOC:          |     234 |   *** |      MONSTER |       234 |
metrics are OK
is_option(Begins at: 2093, Ends at:2106)
Complexity:   |       4 |   *** |      MONSTER |         4 |
LOC:          |      14 |   *** |      MONSTER |        14 |
metrics are OK
print_escaped_for_html(Begins at: 1213, Ends at:1227)
Complexity:   |       4 |     * |      WARNING |         4 |
LOC:          |      15 |       |           OK |        15 |
metrics are OK
print_escaped_for_xml(Begins at: 1189, Ends at:1206)
Complexity:   |       7 |       |           OK |         7 |
LOC:          |      18 |       |           OK |        18 |
metrics are OK
set_flag(Begins at: 2054, Ends at:2078)
CalledNBR:    |       4 |   *** |      MONSTER |         4 |
LOC:          |      25 |    ** | BABY-MONSTER |        25 |
metrics are OK
set_option(Begins at: 2108, Ends at:2163)
Complexity:   |       8 |       |           OK |         8 |
CalledNBR:    |      13 |       |           OK |        13 |
LOC:          |      56 |       |           OK |        56 |
metrics are OK
show(Begins at: 2040, Ends at:2052)
metrics are OK
show_options(Begins at: 2010, Ends at:2038)
CalledNBR:    |      11 |       |           OK |        11 |
LOC:          |      29 |       |           OK |        29 |
metrics are OK
split_gisprompt(Begins at: 2562, Ends at:2590)
ParamNBR:     |       4 |       |           OK |         4 |
metrics are OK
split_opts(Begins at: 2397, Ends at:2455)
LOC:          |      59 |     * |      WARNING |        59 |
metrics are OK
uses_new_gisprompt(Begins at: 958, Ends at:983)
LOC:          |      26 |       |           OK |        26 |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  check_double
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/parser.c clones of check_double are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/parser.c  check_int
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/parser.c clones of check_int are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/parser.c  check_double
____________________________________________
Threshold GRASS6 key metrics values at Thu Oct 02 12:22:52 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
