[GRASS-QA] GRASS QA: glynn |evaluate.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sun Oct 5 04:15:36 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/raster/r.mapcalc/evaluate.c
          Function
allocate_buf(Begins at: 23, Ends at:26)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       4 |       |           OK |         4 |
Conclusion:   | this function is a            OK           |
metrics are OK
error_handler(Begins at: 217, Ends at:235)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      19 |       |           OK |        19 |
metrics are OK
evaluate(Begins at: 188, Ends at:209)
Complexity:   |       8 |     * |      WARNING |         8 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      22 |       |           OK |        22 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
evaluate_binding(Begins at: 181, Ends at:184)
CalledNBR:    |       1 |       |           OK |         1 |
metrics are OK
evaluate_constant(Begins at: 98, Ends at:123)
Complexity:   |       9 |     * |      WARNING |         9 |
LOC:          |      26 |       |           OK |        26 |
metrics are OK
evaluate_function(Begins at: 139, Ends at:179)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |      15 |     * |      WARNING |        15 |
LOC:          |      41 |       |           OK |        41 |
metrics are OK
evaluate_map(Begins at: 130, Ends at:137)
LOC:          |       8 |       |           OK |         8 |
metrics are OK
evaluate_variable(Begins at: 125, Ends at:128)
CalledNBR:    |       0 |       |           OK |         0 |
metrics are OK
execute(Begins at: 257, Ends at:359)
Complexity:   |      17 |    ** | BABY-MONSTER |        14 |
CalledNBR:    |      21 |     * |      WARNING |        22 |
LOC:          |     103 |    ** | BABY-MONSTER |        89 |
Conclusion:   | this function is a  BABY-MONSTER           |
metrics are OK
initialize(Begins at: 73, Ends at:94)
metrics are OK
initialize_binding(Begins at: 67, Ends at:71)
LOC:          |       5 |       |           OK |         5 |
metrics are OK
initialize_constant(Begins at: 35, Ends at:38)
metrics are OK
initialize_function(Begins at: 52, Ends at:65)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      14 |       |           OK |        14 |
metrics are OK
initialize_map(Begins at: 45, Ends at:50)
LOC:          |       6 |       |           OK |         6 |
metrics are OK
initialize_variable(Begins at: 40, Ends at:43)
metrics are OK
setup_rand(Begins at: 237, Ends at:255)
CalledNBR:    |       5 |       |           OK |         5 |
metrics are OK
set_buf(Begins at: 28, Ends at:31)
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold GRASS6 key metrics values at Sun Oct 05 04:27:22 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
