[GRASS-QA] GRASS QA: hamish |main.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Mon Oct 6 01:50:46 EDT 2008
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/raster/r.grow/main.c
          Function
distance_euclidian_squared(Begins at: 36, Ends at:39)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
Conclusion:   | this function is a            OK           |
metrics are OK
distance_manhattan(Begins at: 46, Ends at:49)
CalledNBR:    |       2 |       |           OK |         2 |
metrics are OK
distance_maximum(Begins at: 41, Ends at:44)
CalledNBR:    |       3 |       |           OK |         3 |
metrics are OK
main(Begins at: 95, Ends at:307)
Complexity:   |      31 |   *** |      MONSTER |        31 |
CalledNBR:    |      72 |   *** |      MONSTER |        69 |
LOC:          |     213 |   *** |      MONSTER |       208 |
Conclusion:   | this function is a       MONSTER           |
metrics are OK
setup_neighbors(Begins at: 51, Ends at:76)
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
LOC:          |      26 |       |           OK |        26 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
setup_neighbors_euclidian(Begins at: 78, Ends at:83)
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
setup_neighbors_manhattan(Begins at: 90, Ends at:93)
metrics are OK
setup_neighbors_maximum(Begins at: 85, Ends at:88)
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold GRASS6 key metrics values at Mon Oct 06 02:02:45 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
