[GRASS-QA] GRASS QA: pkelly |ami_stream.h | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Mon Oct 6 19:12:37 EDT 2008
Hello pkelly,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/include/iostream/ami_stream.h
          Class
AMI_STREAM(Begins at: 147, Ends at:198)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      2 |      0 |      0 |     14 |      1 |     91 |
|OLD Metrics |      2 |      0 |      0 |     14 |      1 |     91 |
          Class
AMI_STREAM<T>(Begins at: -9999, Ends at:-9999)
|NEW Metrics |      1 |      0 |     37 |    116 |      0 |     66 |
|OLD Metrics |      1 |      0 |     37 |     63 |      0 |     66 |
          Method
eof(Begins at: 627, Ends at:629)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       0 |       |           OK |         0 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       3 |       |           OK |         3 |
Conclusion:   | this function is a            OK           |
metrics are OK
main_memory_usage(Begins at: 447, Ends at:466)
Complexity:   |       6 |     * |      WARNING |         6 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      20 |       |           OK |        20 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
name(Begins at: 400, Ends at:403)
LOC:          |       4 |       |           OK |         4 |
metrics are OK
new_substream(Begins at: 313, Ends at:361)
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
LOC:          |      49 |     * |      WARNING |        49 |
metrics are OK
persist(Begins at: 605, Ends at:607)
ParamNBR:     |       1 |       |           OK |         1 |
metrics are OK
read_array(Begins at: 528, Ends at:554)
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      27 |       |           OK |        27 |
metrics are OK
read_item(Begins at: 498, Ends at:521)
Complexity:   |       4 |       |           OK |         4 |
LOC:          |      24 |       |           OK |        24 |
metrics are OK
seek(Begins at: 410, Ends at:439)
LOC:          |      30 |       |           OK |        30 |
metrics are OK
sprint(Begins at: 619, Ends at:623)
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       5 |       |           OK |         5 |
metrics are OK
stream_len(Begins at: 368, Ends at:383)
Complexity:   |       2 |       |           OK |         2 |
LOC:          |      16 |       |           OK |        16 |
metrics are OK
write_array(Begins at: 583, Ends at:600)
Complexity:   |       3 |       |           OK |         3 |
LOC:          |      18 |       |           OK |        18 |
metrics are OK
write_item(Begins at: 561, Ends at:578)
CalledNBR:    |       8 |       |           OK |         8 |
metrics are OK
          Class
UntypedStream(Begins at: 116, Ends at:144)
|NEW Metrics |      1 |      0 |      1 |      1 |      0 |      0 |
|OLD Metrics |      1 |      0 |      1 |      1 |      0 |      0 |
          Method
get_block_length(Begins at: 139, Ends at:142)
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold GRASS6 key metrics values at Mon Oct 06 19:24:45 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
