[GRASS-QA] GRASS QA: martinl |parse.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Oct 7 16:36:35 EDT 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/raster/r.report/parse.c
          Function
match(Begins at: 269, Ends at:277)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       9 |       |           OK |         9 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
parse_command_line(Begins at: 6, Ends at:195)
Complexity:   |      15 |    ** | BABY-MONSTER |        15 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      55 |   *** |      MONSTER |        55 |
LOC:          |     190 |   *** |      MONSTER |       190 |
Conclusion:   | this function is a       MONSTER           |
metrics are OK
parse_layer(Begins at: 231, Ends at:267)
Complexity:   |       6 |     * |      WARNING |         6 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      21 |     * |      WARNING |        21 |
LOC:          |      37 |       |           OK |        37 |
metrics are OK
parse_units(Begins at: 197, Ends at:229)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |      10 |     * |      WARNING |        10 |
LOC:          |      33 |       |           OK |        33 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold GRASS6 key metrics values at Tue Oct 07 16:48:55 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
