[GRASS-QA] GRASS QA: neteler |stats.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Oct 8 09:03:58 EDT 2008
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/raster/r.univar2/stats.c
          Function
create_univar_stat_struct(Begins at: 19, Ends at:55)
              |          New Metrics           |Old Metrics|
Complexity:   |       6 |     * |      WARNING |         6 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      10 |     * |      WARNING |        10 |
LOC:          |      37 |       |           OK |        37 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
free_univar_stat_struct(Begins at: 61, Ends at:75)
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      15 |       |           OK |        15 |
Conclusion:   | this function is a            OK           |
metrics are OK
print_stats(Begins at: 81, Ends at:243)
Complexity:   |      25 |   *** |      MONSTER |        25 |
CalledNBR:    |      49 |   *** |      MONSTER |        49 |
LOC:          |     163 |   *** |      MONSTER |       163 |
Conclusion:   | this function is a       MONSTER           |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold GRASS6 key metrics values at Wed Oct 08 09:16:27 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
