[GRASS-QA] GRASS QA: martinl |colors.c display.c local_proto.h main.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Oct 9 04:37:39 EDT 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/display/d.rast/colors.c
The system don't find class, method and function
 in this file during analysis!
          File :grass/branches/develbranch_6/display/d.rast/display.c
          Function
cell_draw(Begins at: 54, Ends at:100)
              |          New Metrics           |Old Metrics|
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      47 |     * |      WARNING |        47 |
Conclusion:   | this function is a  BABY-MONSTER           |
metrics are OK
display(Begins at: 12, Ends at:52)
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |      14 |     * |      WARNING |        14 |
LOC:          |      41 |       |           OK |        41 |
metrics are OK
mask_raster_array(Begins at: 102, Ends at:111)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      10 |       |           OK |        10 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/branches/develbranch_6/display/d.rast/local_proto.h
          File :grass/branches/develbranch_6/display/d.rast/main.c
          Function
main(Begins at: 32, Ends at:144)
Complexity:   |       9 |     * |      WARNING |         9 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      38 |   *** |      MONSTER |        38 |
LOC:          |     113 |    ** | BABY-MONSTER |       113 |
Conclusion:   | this function is a       MONSTER           |
metrics are OK
parse_catlist(Begins at: 146, Ends at:176)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      31 |       |           OK |        31 |
metrics are OK
parse_d_mask_rule(Begins at: 241, Ends at:270)
Complexity:   |       6 |     * |      WARNING |         6 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      30 |       |           OK |        30 |
metrics are OK
parse_mask_rule(Begins at: 210, Ends at:239)
metrics are OK
parse_vallist(Begins at: 178, Ends at:208)
metrics are OK
Clone analysis:
____________________________________________
Threshold GRASS6 key metrics values at Thu Oct 09 04:50:18 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
