[GRASS-QA] GRASS QA: neteler |gis.h gisdefs.h color_xform.c local_proto.h ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Oct 17 16:03:05 EDT 2008
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/include/gis.h
          Class
Categories(Begins at: 445, Ends at:469)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
Cell_head(Begins at: 250, Ends at:272)
          Class
Cell_stats(Begins at: 485, Ends at:500)
          Class
Cell_stats_node(Begins at: 487, Ends at:493)
          Class
Colors(Begins at: 315, Ends at:333)
          Class
FPRange(Begins at: 520, Ends at:525)
          Class
FPReclass(Begins at: 370, Ends at:392)
          Class
FPReclass_table(Begins at: 360, Ends at:366)
          Class
Flag(Begins at: 593, Ends at:601)
          Class
GModule(Begins at: 603, Ends at:611)
          Class
G_3dview(Begins at: 530, Ends at:555)
          Class
Histogram(Begins at: 502, Ends at:511)
          Class
Histogram_list(Begins at: 506, Ends at:510)
          Class
History(Begins at: 471, Ends at:483)
          Class
Key_Value(Begins at: 557, Ends at:563)
          Class
Option(Begins at: 565, Ends at:591)
|NEW Metrics |      1 |      0 |      0 |      1 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      1 |      0 |      0 |
          Class
Quant(Begins at: 402, Ends at:443)
          Class
Quant_table(Begins at: 394, Ends at:400)
          Class
Range(Begins at: 513, Ends at:518)
          Class
Reclass(Begins at: 349, Ends at:358)
          Class
TimeStamp(Begins at: 613, Ends at:617)
          Class
_Color_Info_(Begins at: 288, Ends at:313)
          Class
_Color_Rule_(Begins at: 274, Ends at:286)
Clone analysis:
This file does not contain cloned functions
          File :grass/branches/develbranch_6/include/gisdefs.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/branches/develbranch_6/lib/gis/color_xform.c
          Function
G_histogram_eq_colors(Begins at: 59, Ends at:118)
              |          New Metrics           |Old Metrics|
Complexity:   |       7 |     * |      WARNING |         7 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      13 |     * |      WARNING |        13 |
LOC:          |      60 |     * |      WARNING |        60 |
Conclusion:   | this function is a       WARNING           |
 at least 4 values are close to an outlier please consider revising code!
G_log_colors(Begins at: 129, Ends at:179)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      51 |     * |      WARNING |        51 |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
          File :grass/branches/develbranch_6/raster/r.colors/local_proto.h
          File :grass/branches/develbranch_6/raster/r.colors/main.c
          Function
find_rule(Begins at: 86, Ends at:95)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      10 |       |           OK |        10 |
Conclusion:   | this function is a            OK           |
metrics are OK
list_rules(Begins at: 78, Ends at:84)
Complexity:   |       2 |       |           OK |         2 |
LOC:          |       7 |       |           OK |         7 |
metrics are OK
main(Begins at: 97, Ends at:386)
Complexity:   |      39 |   *** |      MONSTER |        39 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     108 |   *** |      MONSTER |       108 |
LOC:          |     290 |   *** |      MONSTER |       290 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
rules_list(Begins at: 52, Ends at:76)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      25 |       |           OK |        25 |
metrics are OK
scan_rules(Begins at: 36, Ends at:50)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      15 |       |           OK |        15 |
metrics are OK
Clone analysis:
          File :grass/branches/develbranch_6/raster/r.colors/stats.c
          Function
get_stats(Begins at: 24, Ends at:50)
CalledNBR:    |      15 |     * |      WARNING |        15 |
LOC:          |      27 |       |           OK |        27 |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Fri Oct 17 16:17:25 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
	Please visite our web site on your project at :
	http://web.soccerlab.polymtl.ca/project-manager/index.html
