[GRASS-QA] GRASS QA: glynn |range.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Oct 17 16:37:05 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/gis/range.c
          Function
G_construct_default_range(Begins at: 112, Ends at:118)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       7 |       |           OK |         7 |
Conclusion:   | this function is a            OK           |
metrics are OK
G_get_fp_range_min_max(Begins at: 667, Ends at:687)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      21 |       |           OK |        21 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
G_get_range_min_max(Begins at: 608, Ends at:627)
LOC:          |      20 |       |           OK |        20 |
G_init_fp_range(Begins at: 642, Ends at:649)
LOC:          |       8 |       |           OK |         8 |
metrics are OK
G_init_range(Begins at: 579, Ends at:586)
metrics are OK
G_read_fp_range(Begins at: 139, Ends at:195)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |      18 |     * |      WARNING |        18 |
LOC:          |      57 |     * |      WARNING |        57 |
 at least 4 values are close to an outlier please consider revising code!
G_read_range(Begins at: 226, Ends at:311)
Complexity:   |      15 |    ** | BABY-MONSTER |        15 |
CalledNBR:    |      23 |    ** | BABY-MONSTER |        23 |
LOC:          |      86 |     * |      WARNING |        86 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
G_row_update_fp_range(Begins at: 524, Ends at:562)
Complexity:   |      10 |     * |      WARNING |        10 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      39 |       |           OK |        39 |
 at least 2 values are close to an outlier please consider revising code!
G_row_update_range(Begins at: 489, Ends at:494)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       6 |       |           OK |         6 |
G_update_fp_range(Begins at: 456, Ends at:471)
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       2 |       |           OK |         2 |
LOC:          |      16 |       |           OK |        16 |
metrics are OK
G_update_range(Begins at: 436, Ends at:452)
LOC:          |      17 |       |           OK |        17 |
metrics are OK
G_write_fp_range(Begins at: 380, Ends at:416)
CalledNBR:    |      13 |     * |      WARNING |        13 |
LOC:          |      37 |       |           OK |        37 |
G_write_range(Begins at: 334, Ends at:363)
CalledNBR:    |      12 |     * |      WARNING |        12 |
LOC:          |      30 |       |           OK |        30 |
G__remove_fp_range(Begins at: 95, Ends at:100)
metrics are OK
G__row_update_range(Begins at: 498, Ends at:520)
Complexity:   |       6 |     * |      WARNING |         6 |
LOC:          |      23 |       |           OK |        23 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Fri Oct 17 16:51:25 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
	Please visite our web site on your project at :
	http://web.soccerlab.polymtl.ca/project-manager/index.html
