[GRASS-QA] GRASS QA: neteler |main.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Oct 24 23:36:14 EDT 2008
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass-addons/raster/r.sun_horizon/r.horizon/main.c
          Function
amax1(Begins at: 659, Ends at:672)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      14 |       |           OK |        14 |
Conclusion:   | this function is a            OK           |
metrics are OK
amin1(Begins at: 674, Ends at:687)
metrics are OK
calculate(Begins at: 1037, Ends at:1273)
Complexity:   |      28 |   *** |      MONSTER |        28 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |      34 |    ** | BABY-MONSTER |        34 |
LOC:          |     237 |   *** |      MONSTER |       237 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
calculate_shadow(Begins at: 774, Ends at:876)
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       0 |       |           OK |         0 |
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |     103 |    ** | BABY-MONSTER |       103 |
Conclusion:   | this function is a  BABY-MONSTER           |
calculate_shadow_onedirection(Begins at: 764, Ends at:770)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       7 |       |           OK |         7 |
metrics are OK
com_par(Begins at: 724, Ends at:746)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      23 |       |           OK |        23 |
metrics are OK
distance(Begins at: 146, Ends at:155)
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      10 |       |           OK |        10 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
horizon_height(Begins at: 748, Ends at:761)
metrics are OK
INPUT(Begins at: 534, Ends at:605)
Complexity:   |      15 |    ** | BABY-MONSTER |        15 |
CalledNBR:    |      18 |     * |      WARNING |        18 |
LOC:          |      72 |     * |      WARNING |        72 |
isMode(Begins at: 134, Ends at:137)
LOC:          |       4 |       |           OK |         4 |
metrics are OK
main(Begins at: 159, Ends at:530)
Complexity:   |      37 |   *** |      MONSTER |        37 |
CalledNBR:    |     112 |   *** |      MONSTER |       112 |
LOC:          |     372 |   *** |      MONSTER |       372 |
max(Begins at: 705, Ends at:718)
metrics are OK
min(Begins at: 690, Ends at:703)
metrics are OK
new_point(Begins at: 881, Ends at:919)
LOC:          |      39 |       |           OK |        39 |
metrics are OK
OUTGR(Begins at: 610, Ends at:656)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |      17 |     * |      WARNING |        17 |
LOC:          |      47 |     * |      WARNING |        47 |
 at least 3 values are close to an outlier please consider revising code!
searching(Begins at: 993, Ends at:1031)
Complexity:   |       7 |     * |      WARNING |         7 |
setMode(Begins at: 138, Ends at:141)
metrics are OK
test_low_res(Begins at: 922, Ends at:990)
CalledNBR:    |      15 |     * |      WARNING |        15 |
LOC:          |      69 |     * |      WARNING |        69 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Fri Oct 24 23:52:09 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
