[GRASS-QA] GRASS QA: glynn |db.c dbe.c proto.h replace.c ...| 1 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Sep 4 14:35:08 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/db/drivers/mysql/db.c
          Function
db__driver_close_database(Begins at: 74, Ends at:80)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         0 |
CalledNBR:    |       2 |       |           OK |         3 |
LOC:          |       7 |       |           OK |        11 |
Conclusion:   | this function is a            OK           |
metrics are OK
db__driver_open_database(Begins at: 22, Ends at:72)
Complexity:   |       4 |       |           OK |         7 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      18 |     * |      WARNING |        43 |
LOC:          |      51 |     * |      WARNING |       105 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
replace_variables(Begins at: 142, Ends at:188)
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      47 |     * |      WARNING |        47 |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/trunk/db/drivers/mysql/db.c clones of replace_variables are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/db/drivers/mysql/db.c  replace_variables
          File :grass/trunk/db/drivers/mysql/dbe.c
          Function
db__driver_close_database(Begins at: 91, Ends at:99)
Complexity:   |       1 |       |           OK |           |
ParamNBR:     |       1 |       |           OK |           |
CalledNBR:    |       3 |       |           OK |           |
LOC:          |       9 |       |           OK |           |
metrics are OK
db__driver_open_database(Begins at: 22, Ends at:89)
Complexity:   |       5 |       |           OK |           |
CalledNBR:    |      30 |    ** | BABY-MONSTER |           |
LOC:          |      68 |     * |      WARNING |           |
Conclusion:   | this function is a  BABY-MONSTER           |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/db/drivers/mysql/proto.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/db/drivers/mysql/replace.c
          Function
replace_variables(Begins at: 23, Ends at:69)
ParamNBR:     |       3 |     * |      WARNING |           |
CalledNBR:    |      20 |     * |      WARNING |           |
LOC:          |      47 |     * |      WARNING |           |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/btree/try.c
          Function
cmp(Begins at: 21, Ends at:24)
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
main(Begins at: 26, Ends at:58)
Complexity:   |       8 |     * |      WARNING |         8 |
CalledNBR:    |      19 |     * |      WARNING |        19 |
LOC:          |      33 |       |           OK |        33 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/btree/test/try.c
          File :grass/trunk/lib/cdhc/c-drive.c
          Function
main(Begins at: 6, Ends at:48)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |      28 |    ** | BABY-MONSTER |        28 |
LOC:          |      43 |     * |      WARNING |        43 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/linkm/destroy.c
          Function
link_destroy(Begins at: 10, Ends at:17)
LOC:          |       8 |       |           OK |         8 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/linkm/linkm.c
          Class
link(Begins at: 18, Ends at:22)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Function
main(Begins at: 24, Ends at:53)
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      30 |       |           OK |        30 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/linkm/malloc.c
          Class
link(Begins at: 17, Ends at:21)
          Function
main(Begins at: 23, Ends at:38)
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      16 |       |           OK |        16 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/linkm/speed.c
          Class
link(Begins at: 14, Ends at:18)
          Function
CalledNBR:    |       9 |       |           OK |         9 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/linkm/speed2.c
          Class
link(Begins at: 16, Ends at:20)
          Function
main(Begins at: 26, Ends at:69)
Complexity:   |       3 |       |           OK |         3 |
LOC:          |      44 |     * |      WARNING |        44 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/linkm/speed3.c
          Class
          Function
main(Begins at: 24, Ends at:68)
Complexity:   |       4 |       |           OK |         4 |
LOC:          |      45 |     * |      WARNING |        45 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/linkm/try.c
          Class
          Function
add_link(Begins at: 75, Ends at:84)
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
add_link_rev(Begins at: 66, Ends at:73)
metrics are OK
dumplist(Begins at: 86, Ends at:96)
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      11 |       |           OK |        11 |
metrics are OK
main(Begins at: 23, Ends at:64)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      42 |     * |      WARNING |        42 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/linkm/try2.c
          Class
          Function
add_link(Begins at: 80, Ends at:89)
metrics are OK
add_link_rev(Begins at: 71, Ends at:78)
metrics are OK
dumplist(Begins at: 91, Ends at:101)
metrics are OK
main(Begins at: 24, Ends at:69)
LOC:          |      46 |     * |      WARNING |        46 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/linkm/test/linkm.c
          File :grass/trunk/lib/linkm/test/malloc.c
          File :grass/trunk/lib/linkm/test/speed.c
          File :grass/trunk/lib/linkm/test/speed2.c
          File :grass/trunk/lib/linkm/test/speed3.c
          File :grass/trunk/lib/linkm/test/try.c
          File :grass/trunk/lib/linkm/test/try2.c
          File :grass/trunk/lib/segment/debug.c
          Function
check(Begins at: 105, Ends at:128)
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      24 |       |           OK |        24 |
metrics are OK
segment_get(Begins at: 48, Ends at:62)
LOC:          |      15 |       |           OK |        15 |
metrics are OK
segment_put(Begins at: 86, Ends at:102)
LOC:          |      17 |       |           OK |        17 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/segment/try.c
          Function
main(Begins at: 41, Ends at:111)
Complexity:   |      14 |    ** | BABY-MONSTER |        14 |
CalledNBR:    |      29 |    ** | BABY-MONSTER |        29 |
LOC:          |      71 |     * |      WARNING |        71 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/vector/rtree/sphvol.c
          Function
main(Begins at: 59, Ends at:71)
LOC:          |      13 |       |           OK |        13 |
metrics are OK
print_volume(Begins at: 45, Ends at:48)
metrics are OK
sphere_volume(Begins at: 50, Ends at:57)
CalledNBR:    |       3 |       |           OK |         3 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/vector/rtree/test.c
          Function
main(Begins at: 41, Ends at:63)
ParamNBR:     |       0 |       |           OK |         0 |
LOC:          |      23 |       |           OK |        23 |
metrics are OK
MySearchCallback(Begins at: 34, Ends at:39)
LOC:          |       6 |       |           OK |         6 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/vector/rtree/docs/test.c
          File :grass/trunk/visualization/nviz/src/buildPg.c
          Function
buildPg(Begins at: 6, Ends at:17)
LOC:          |      12 |       |           OK |        12 |
metrics are OK
buildPgSite(Begins at: 19, Ends at:28)
metrics are OK
Clone analysis:
          File :grass/trunk/visualization/nviz/src/getCat.c
          Function
fillSQLstruct(Begins at: 69, Ends at:94)
LOC:          |      26 |       |           OK |        26 |
metrics are OK
getCat(Begins at: 8, Ends at:67)
CalledNBR:    |      14 |     * |      WARNING |        14 |
LOC:          |      60 |     * |      WARNING |        60 |
metrics are OK
Clone analysis:
          File :grass/trunk/visualization/nviz/src/openvect.c
          Function
openvect(Begins at: 3, Ends at:13)
metrics are OK
Clone analysis:
          File :grass/trunk/visualization/nviz/src/query_postgr.c
          File :grass/trunk/visualization/nviz/src/runPg.c
          Function
do_query(Begins at: 95, Ends at:180)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |      44 |   *** |      MONSTER |        44 |
LOC:          |      86 |     * |      WARNING |        86 |
Conclusion:   | this function is a       MONSTER           |
metrics are OK
runPg(Begins at: 9, Ends at:93)
Complexity:   |      11 |     * |      WARNING |        11 |
LOC:          |      85 |     * |      WARNING |        85 |
metrics are OK
Clone analysis:
          File :grass/trunk/visualization/nviz/src/vect.c
____________________________________________
Threshold GRASS6 key metrics values at Thu Sep 04 14:47:20 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
