[GRASS-QA] GRASS QA: martinl |break.c | 3 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Sep 5 11:07:17 EDT 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/vector/vedit/break.c
          Function
connect_lines(Begins at: 196, Ends at:325)
              |          New Metrics           |Old Metrics|
Complexity:   |      13 |     * |      WARNING |        13 |
ParamNBR:     |       6 |     * |      WARNING |         6 |
CalledNBR:    |      34 |       |           OK |        34 |
LOC:          |     130 |     * |      WARNING |       130 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
Vedit_connect_lines(Begins at: 151, Ends at:194)
Complexity:   |       7 |    ** | BABY-MONSTER |         7 |
ParamNBR:     |       3 |    ** | BABY-MONSTER |         3 |
CalledNBR:    |       8 |    ** | BABY-MONSTER |         8 |
LOC:          |      44 |    ** | BABY-MONSTER |        44 |
Conclusion:   | this function is a  BABY-MONSTER           |
metrics are OK
Vedit_split_lines(Begins at: 33, Ends at:132)
Complexity:   |      13 |    ** | BABY-MONSTER |        13 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      23 |    ** | BABY-MONSTER |        23 |
LOC:          |     100 |    ** | BABY-MONSTER |       100 |
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
  Vedit_connect_lines  Vedit_split_lines
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/vedit/break.c clones of connect_lines are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/vedit/break.c  connect_lines
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/vedit/break.c clones of Vedit_connect_lines are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/vedit/break.c  Vedit_connect_lines
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/vedit/break.c clones of Vedit_split_lines are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/vedit/break.c  Vedit_split_lines
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 11:12:39 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
