[GRASS-QA] GRASS QA: glynn |read.c | 2 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Sep 5 12:30:57 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/vector/Vlib/read.c
          Function
format(Begins at: 30, Ends at:34)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       0 |       |           OK |         0 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       5 |       |           OK |         5 |
Conclusion:   | this function is a            OK           |
metrics are OK
read_next_dummy(Begins at: 24, Ends at:27)
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
Vect_area_alive(Begins at: 155, Ends at:161)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       2 |       |           OK |         2 |
LOC:          |       7 |       |           OK |         7 |
metrics are OK
Vect_isle_alive(Begins at: 172, Ends at:178)
metrics are OK
Vect_line_alive(Begins at: 121, Ends at:127)
metrics are OK
Vect_node_alive(Begins at: 138, Ends at:144)
metrics are OK
Vect_read_line(Begins at: 95, Ends at:110)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      16 |       |           OK |        16 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
Vect_read_next_line(Begins at: 70, Ends at:82)
ParamNBR:     |       3 |     * |      WARNING |         3 |
LOC:          |      13 |       |           OK |        13 |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  Vect_read_next_line
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/read.c clones of Vect_read_line are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/Vlib/read.c  Vect_read_line
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/read.c clones of Vect_read_next_line are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/Vlib/read.c  Vect_read_next_line
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 12:36:20 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
