[GRASS-QA] GRASS QA: rmatev |vlib_buffer.c vlib_buffer.c | 2 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Sep 5 15:22:54 EDT 2008
Hello rmatev,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass-addons/vector/v.buffer2/vlib_buffer.c
The system don't find class, method and function
 in this file during analysis!
          File :grass-addons/vector/v.parallel2/vlib_buffer.c
          Function
add_line_to_array(Begins at: 687, Ends at:695)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       9 |       |           OK |         9 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
angular_tolerance(Begins at: 127, Ends at:135)
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       3 |       |           OK |         3 |
metrics are OK
convolution_line(Begins at: 297, Ends at:425)
Complexity:   |      16 |    ** | BABY-MONSTER |        16 |
ParamNBR:     |       9 |   *** |      MONSTER |         9 |
CalledNBR:    |      30 |    ** | BABY-MONSTER |        30 |
LOC:          |     129 |    ** | BABY-MONSTER |       129 |
Conclusion:   | this function is a       MONSTER           |
metrics are OK
elliptic_tangent(Begins at: 77, Ends at:92)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      16 |       |           OK |        16 |
Conclusion:   | this function is a  BABY-MONSTER           |
metrics are OK
elliptic_transform(Begins at: 52, Ends at:69)
LOC:          |      18 |       |           OK |        18 |
metrics are OK
extract_contour(Begins at: 432, Ends at:528)
Complexity:   |      12 |     * |      WARNING |        12 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      97 |    ** | BABY-MONSTER |        97 |
metrics are OK
extract_inner_contour(Begins at: 588, Ends at:615)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      28 |       |           OK |        28 |
metrics are OK
extract_outer_contour(Begins at: 540, Ends at:579)
Complexity:   |       6 |     * |      WARNING |         6 |
LOC:          |      40 |       |           OK |        40 |
metrics are OK
line_coefficients(Begins at: 98, Ends at:103)
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
line_intersection(Begins at: 110, Ends at:125)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
metrics are OK
norm_vector(Begins at: 27, Ends at:40)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      14 |       |           OK |        14 |
metrics are OK
parallel_line(Begins at: 149, Ends at:294)
Complexity:   |      20 |    ** | BABY-MONSTER |        20 |
ParamNBR:     |      10 |   *** |      MONSTER |        10 |
LOC:          |     146 |   *** |      MONSTER |       146 |
metrics are OK
parallel_line_b(Begins at: 697, Ends at:794)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |      35 |    ** | BABY-MONSTER |        35 |
LOC:          |      98 |    ** | BABY-MONSTER |        98 |
metrics are OK
point_in_buf(Begins at: 622, Ends at:684)
Complexity:   |       7 |     * |      WARNING |         7 |
LOC:          |      63 |     * |      WARNING |        63 |
metrics are OK
rotate_vector(Begins at: 42, Ends at:46)
LOC:          |       5 |       |           OK |         5 |
metrics are OK
Vect_line_buffer(Begins at: 830, Ends at:926)
Complexity:   |      10 |     * |      WARNING |        10 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      26 |    ** | BABY-MONSTER |        26 |
metrics are OK
Vect_line_parallel2(Begins at: 806, Ends at:817)
LOC:          |      12 |       |           OK |        12 |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  vect
In /var/project-manager/grass/grassSVN/grass-addons/vector/v.parallel2/vlib_buffer.c clones of norm_vector are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/buffer.c  vect
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/Vlib/buffer.c  vect
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 15:28:18 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
