[GRASS-QA] GRASS QA: martinl |init.cpp nviz.h | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Sep 9 10:18:23 EDT 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/gui/wxpython/nviz/init.cpp
          Class
Nviz(Begins at: -9999, Ends at:-9999)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      7 |     55 |      0 |     15 |
|OLD Metrics |      1 |      0 |      7 |     55 |      0 |     15 |
          Method
InitView(Begins at: 91, Ends at:113)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       0 |       |           OK |         0 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      23 |       |           OK |        23 |
Conclusion:   | this function is a            OK           |
metrics are OK
Nviz(Begins at: 35, Ends at:56)
ParamNBR:     |       1 |       |           OK |         1 |
LOC:          |      22 |       |           OK |        22 |
metrics are OK
Reset(Begins at: 122, Ends at:131)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
SetBgColor(Begins at: 143, Ends at:148)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
SetDisplay(Begins at: 81, Ends at:89)
LOC:          |       9 |       |           OK |         9 |
metrics are OK
~Nviz(Begins at: 61, Ends at:73)
LOC:          |      13 |       |           OK |        13 |
metrics are OK
          Function
print_error(Begins at: 150, Ends at:160)
ParamNBR:     |       2 |       |           OK |         2 |
LOC:          |      11 |       |           OK |        11 |
metrics are OK
print_percent(Begins at: 221, Ends at:229)
metrics are OK
print_sentence(Begins at: 167, Ends at:219)
Complexity:   |       8 |     * |      WARNING |         8 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      18 |     * |      WARNING |        18 |
LOC:          |      53 |     * |      WARNING |        53 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
swap_gl(Begins at: 133, Ends at:136)
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/gui/wxpython/nviz/nviz.h
          Class
Nviz(Begins at: 29, Ends at:109)
|NEW Metrics |      1 |      0 |      0 |     49 |      0 |   1176 |
|OLD Metrics |      1 |      0 |      0 |     49 |      0 |   1176 |
Clone analysis:
____________________________________________
Threshold GRASS6 key metrics values at Tue Sep 09 10:24:36 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
