[GRASS-QA] GRASS QA: martinl |cats.cpp driver.h driver_draw.cpp driver_select.cpp | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Sep 9 19:14:11 EDT 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/gui/wxpython/vdigit/cats.cpp
          Class
Digit(Begins at: -9999, Ends at:-9999)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |     37 |    113 |      0 |     21 |
|OLD Metrics |      1 |      0 |     37 |    113 |      0 |     21 |
          Method
CopyCats(Begins at: 293, Ends at:298)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       6 |       |           OK |         6 |
Conclusion:   | this function is a            OK           |
metrics are OK
GetCategory(Begins at: 90, Ends at:98)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |       9 |       |           OK |         9 |
metrics are OK
GetLayers(Begins at: 134, Ends at:144)
ParamNBR:     |       0 |       |           OK |         0 |
LOC:          |      11 |       |           OK |        11 |
metrics are OK
GetLineCats(Begins at: 153, Ends at:202)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      50 |     * |      WARNING |        50 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
InitCats(Begins at: 26, Ends at:80)
Complexity:   |      11 |     * |      WARNING |        11 |
CalledNBR:    |      13 |     * |      WARNING |        13 |
LOC:          |      55 |     * |      WARNING |        55 |
metrics are OK
SetCategory(Begins at: 109, Ends at:125)
LOC:          |      17 |       |           OK |        17 |
metrics are OK
SetLineCats(Begins at: 215, Ends at:282)
Complexity:   |      10 |     * |      WARNING |        10 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      19 |     * |      WARNING |        19 |
LOC:          |      68 |     * |      WARNING |        68 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/gui/wxpython/vdigit/driver.h
          Class
DisplayDriver(Begins at: 32, Ends at:217)
|NEW Metrics |      1 |      0 |      0 |     33 |      0 |    528 |
|OLD Metrics |      1 |      0 |      0 |     33 |      0 |    528 |
          Class
_region(Begins at: 69, Ends at:83)
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
_settings(Begins at: 90, Ends at:115)
          Class
_topology(Begins at: 117, Ends at:135)
          Class
symbol(Begins at: 85, Ends at:88)
Clone analysis:
          File :grass/trunk/gui/wxpython/vdigit/driver_draw.cpp
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/gui/wxpython/vdigit/driver_select.cpp
____________________________________________
Threshold GRASS6 key metrics values at Tue Sep 09 19:20:29 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
