[GRASS-QA] GRASS QA: hamish |collect_ori.c main.c select_linksB.c spot.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Sep 10 12:46:39 EDT 2008
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/raster/wildfire/r.spread/collect_ori.c
The system don't find class, method and function
 in this file during analysis!
          File :grass/branches/develbranch_6/raster/wildfire/r.spread/main.c
          Function
main(Begins at: 79, Ends at:652)
              |          New Metrics           |Old Metrics|
Complexity:   |      68 |   *** |      MONSTER |        68 |
ParamNBR:     |       2 |   *** |      MONSTER |         2 |
CalledNBR:    |     277 |   *** |      MONSTER |       277 |
LOC:          |     574 |   *** |      MONSTER |       574 |
Conclusion:   | this function is a       MONSTER           |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/branches/develbranch_6/raster/wildfire/r.spread/select_linksB.c
          File :grass/branches/develbranch_6/raster/wildfire/r.spread/spot.c
          Function
spot(Begins at: 59, Ends at:133)
Complexity:   |       7 |   *** |      MONSTER |         7 |
CalledNBR:    |      15 |   *** |      MONSTER |        15 |
LOC:          |      75 |   *** |      MONSTER |        75 |
metrics are OK
Clone analysis:
____________________________________________
Threshold GRASS6 key metrics values at Wed Sep 10 12:53:06 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         0 |         0 |         0 |
ParamNBR:             |         0 |         0 |         0 |
CalledNBR:            |         0 |         0 |         0 |
LOC:                  |         0 |         0 |         0 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
