[GRASS-QA] GRASS QA: mlennert |dbfexe.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sun Apr 26 01:49:22 EDT 2009
Hello mlennert,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/db/drivers/dbf/dbfexe.c
          Function
cmp_row_asc(Begins at: 469, Ends at:506)
              |          New Metrics           |Old Metrics|
Complexity:   |       9 |     * |      WARNING |         9 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      38 |       |           OK |        38 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
cmp_row_desc(Begins at: 508, Ends at:513)
Complexity:   |       1 |       |           OK |         1 |
LOC:          |       6 |       |           OK |         6 |
Conclusion:   | this function is a            OK           |
metrics are OK
eval_node(Begins at: 644, Ends at:939)
Complexity:   |      72 |   *** |      MONSTER |        72 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      21 |     * |      WARNING |        21 |
LOC:          |     296 |   *** |      MONSTER |       296 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
eval_node_type(Begins at: 988, Ends at:1138)
Complexity:   |      44 |   *** |      MONSTER |        44 |
CalledNBR:    |      10 |     * |      WARNING |        10 |
LOC:          |     151 |   *** |      MONSTER |       151 |
eval_val(Begins at: 346, Ends at:406)
Complexity:   |      10 |     * |      WARNING |        10 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      12 |     * |      WARNING |        12 |
LOC:          |      61 |     * |      WARNING |        61 |
 at least 4 values are close to an outlier please consider revising code!
execute(Begins at: 45, Ends at:317)
Complexity:   |      42 |   *** |      MONSTER |        42 |
CalledNBR:    |      61 |   *** |      MONSTER |        61 |
LOC:          |     273 |   *** |      MONSTER |       273 |
get_col_def(Begins at: 320, Ends at:344)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      25 |       |           OK |        25 |
 at least 2 values are close to an outlier please consider revising code!
sel(Begins at: 517, Ends at:629)
Complexity:   |      18 |    ** | BABY-MONSTER |        18 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      26 |    ** | BABY-MONSTER |        26 |
LOC:          |     113 |    ** | BABY-MONSTER |       113 |
Conclusion:   | this function is a  BABY-MONSTER           |
set_val(Begins at: 408, Ends at:464)
Complexity:   |      11 |     * |      WARNING |        11 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      57 |     * |      WARNING |        57 |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Sun Apr 26 02:00:59 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
