[GRASS-QA] GRASS QA: hcho |add_lwpolyline.c add_polyline.c make_arc.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Apr 30 11:46:10 EDT 2009
Hello hcho,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/vector/v.in.dxf/add_lwpolyline.c
          Function
add_lwpolyline(Begins at: 5, Ends at:114)
              |          New Metrics           |Old Metrics|
Complexity:   |      20 |    ** | BABY-MONSTER |        20 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |     110 |    ** | BABY-MONSTER |       110 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :grass/branches/develbranch_6/vector/v.in.dxf/add_polyline.c
          Function
add_polyline(Begins at: 7, Ends at:252)
Complexity:   |      43 |   *** |      MONSTER |        43 |
CalledNBR:    |      40 |   *** |      MONSTER |        40 |
LOC:          |     246 |   *** |      MONSTER |       246 |
Conclusion:   | this function is a       MONSTER           |
write_pnts(Begins at: 254, Ends at:288)
Complexity:   |       6 |     * |      WARNING |         6 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      35 |       |           OK |        35 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
          File :grass/branches/develbranch_6/vector/v.in.dxf/make_arc.c
          Function
make_arc(Begins at: 7, Ends at:75)
Complexity:   |       8 |     * |      WARNING |         8 |
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |      25 |    ** | BABY-MONSTER |        25 |
LOC:          |      69 |     * |      WARNING |        69 |
make_arc_from_polyline(Begins at: 77, Ends at:173)
Complexity:   |      13 |    ** | BABY-MONSTER |        13 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      26 |    ** | BABY-MONSTER |        26 |
LOC:          |      97 |    ** | BABY-MONSTER |        97 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Apr 30 11:58:44 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
