[GRASS-QA] GRASS QA: hamish |fiducial.c plot1.c symbol.h stroke.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sun Aug 9 04:07:27 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/display/d.grid/fiducial.c
          Function
plot_cross(Begins at: 9, Ends at:12)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
plot_fiducial(Begins at: 15, Ends at:19)
LOC:          |       5 |       |           OK |         5 |
plot_symbol(Begins at: 22, Ends at:59)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      15 |     * |      WARNING |        15 |
LOC:          |      38 |       |           OK |        38 |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/display/d.vect/plot1.c
          Function
plot1(Begins at: 80, Ends at:479)
Complexity:   |      60 |       |           OK |        60 |
ParamNBR:     |      18 |     * |      WARNING |        18 |
CalledNBR:    |      95 |     * |      WARNING |        95 |
LOC:          |     400 |       |           OK |       400 |
plot_polygon(Begins at: 62, Ends at:75)
Complexity:   |       5 |   *** |      MONSTER |         5 |
ParamNBR:     |       3 |   *** |      MONSTER |         3 |
CalledNBR:    |       3 |   *** |      MONSTER |         3 |
LOC:          |      14 |   *** |      MONSTER |        14 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
plot_polyline(Begins at: 44, Ends at:57)
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      14 |       |           OK |        14 |
Clone analysis:
          File :grass/trunk/include/symbol.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/lib/symbol/stroke.c
          Function
S_stroke(Begins at: 147, Ends at:174)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      28 |       |           OK |        28 |
add_coor(Begins at: 24, Ends at:35)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      12 |       |           OK |        12 |
stroke_chain(Begins at: 42, Ends at:140)
Complexity:   |      22 |   *** |      MONSTER |        22 |
LOC:          |      99 |    ** | BABY-MONSTER |        99 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Sun Aug 09 03:54:15 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
