[GRASS-QA] GRASS QA: martinl |do_areas.c do_lines.c main.c raster.c ...| 1 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Feb 3 11:37:28 EST 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/vector/v.to.rast/do_areas.c
          Function
compare(Begins at: 136, Ends at:146)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      11 |       |           OK |        11 |
Conclusion:   | this function is a            OK           |
metrics are OK
do_areas(Begins at: 22, Ends at:84)
Complexity:   |      12 |     * |      WARNING |        12 |
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |      22 |     * |      WARNING |        22 |
LOC:          |      63 |     * |      WARNING |        63 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
sort_areas(Begins at: 87, Ends at:133)
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      17 |     * |      WARNING |        17 |
LOC:          |      47 |     * |      WARNING |        47 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/trunk/vector/v.to.rast/do_areas.c clones of compare are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/histogram.c  cmp
          File :grass/trunk/vector/v.to.rast/do_lines.c
          Function
deg_angle(Begins at: 155, Ends at:173)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      19 |       |           OK |        19 |
 at least 1 values are close to an outlier please consider revising code!
do_lines(Begins at: 16, Ends at:128)
Complexity:   |      26 |   *** |      MONSTER |        26 |
ParamNBR:     |      10 |   *** |      MONSTER |        10 |
CalledNBR:    |      24 |    ** | BABY-MONSTER |        24 |
LOC:          |     113 |    ** | BABY-MONSTER |       113 |
Conclusion:   | this function is a       MONSTER           |
plot_line(Begins at: 131, Ends at:143)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      13 |       |           OK |        13 |
plot_points(Begins at: 176, Ends at:183)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       8 |       |           OK |         8 |
v2angle(Begins at: 147, Ends at:152)
Complexity:   |       1 |       |           OK |         1 |
LOC:          |       6 |       |           OK |         6 |
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/vector/v.to.rast/main.c
          Function
main(Begins at: 27, Ends at:141)
Complexity:   |      13 |    ** | BABY-MONSTER |        13 |
CalledNBR:    |      42 |   *** |      MONSTER |        42 |
LOC:          |     115 |    ** | BABY-MONSTER |       115 |
Clone analysis:
          File :grass/trunk/vector/v.to.rast/raster.c
          Function
begin_rasterization(Begins at: 34, Ends at:87)
Complexity:   |       9 |     * |      WARNING |         9 |
LOC:          |      54 |     * |      WARNING |        54 |
cell_dot(Begins at: 214, Ends at:222)
LOC:          |       9 |       |           OK |         9 |
metrics are OK
configure_plot(Begins at: 90, Ends at:132)
ParamNBR:     |       1 |       |           OK |         1 |
LOC:          |      43 |     * |      WARNING |        43 |
 at least 2 values are close to an outlier please consider revising code!
cont(Begins at: 189, Ends at:212)
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      24 |       |           OK |        24 |
metrics are OK
dcell_dot(Begins at: 224, Ends at:232)
metrics are OK
move(Begins at: 181, Ends at:187)
LOC:          |       7 |       |           OK |         7 |
metrics are OK
output_raster(Begins at: 135, Ends at:161)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      27 |       |           OK |        27 |
set_cat(Begins at: 163, Ends at:170)
metrics are OK
set_dcat(Begins at: 172, Ends at:179)
metrics are OK
Clone analysis:
          File :grass/trunk/vector/v.to.rast/vect2rast.c
          Function
vect_to_rast(Begins at: 9, Ends at:228)
Complexity:   |      39 |   *** |      MONSTER |        39 |
ParamNBR:     |      11 |   *** |      MONSTER |        11 |
CalledNBR:    |      77 |   *** |      MONSTER |        77 |
LOC:          |     220 |   *** |      MONSTER |       220 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Feb 03 12:01:02 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
