[GRASS-QA] GRASS QA: martinl |update.c | 11 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Feb 3 15:16:20 EST 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/vector/v.to.db/update.c
          Function
srch(Begins at: 241, Ends at:251)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      11 |       |           OK |        11 |
Conclusion:   | this function is a            OK           |
metrics are OK
update(Begins at: 9, Ends at:239)
Complexity:   |      56 |   *** |      MONSTER |        56 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      50 |   *** |      MONSTER |        50 |
LOC:          |     231 |   *** |      MONSTER |       231 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file has 11 potentially cloned functions:
  cmp  cmp  cmp  cmp  fcmp  dcmp  dcmp  cmp_exist  cmp  srch_cat
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/vector/v.to.db/update.c clones of srch are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/db/dbmi_client/copy_tab.c  cmp
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/db/dbmi_client/select.c  cmp
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/Vlib/array.c  cmp
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/Vlib/cats.c  cmp
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.coin/make_coin.c  cmp
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.mapcalc/xmedian.c  fcmp
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.mapcalc/xmedian.c  dcmp
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.mapcalc/xmode.c  dcmp
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/vector/v.distance/main.c  cmp_exist
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/vector/v.extract/extract.c  cmp
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/vector/v.what.rast/main.c  srch_cat
____________________________________________
Threshold grass key metrics values at Tue Feb 03 15:39:56 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
