[GRASS-QA] GRASS QA: mmetz |heap.c sp-template.c | 2 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Feb 27 09:30:09 EST 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/vector/dglib/heap.c
          Function
dglHeapExtractMax(Begins at: 138, Ends at:168)
              |          New Metrics           |Old Metrics|
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      31 |       |           OK |        31 |
Conclusion:   | this function is a            OK           |
metrics are OK
dglHeapExtractMin(Begins at: 79, Ends at:109)
metrics are OK
dglHeapFree(Begins at: 37, Ends at:50)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      14 |       |           OK |        14 |
metrics are OK
dglHeapInit(Begins at: 29, Ends at:35)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
LOC:          |       7 |       |           OK |         7 |
metrics are OK
dglHeapInsertMax(Begins at: 111, Ends at:136)
ParamNBR:     |       4 |     * |      WARNING |         4 |
LOC:          |      26 |       |           OK |        26 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
dglHeapInsertMin(Begins at: 52, Ends at:77)
Clone analysis:
This file has 2 potentially cloned functions:
  dglHeapInsertMax
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/dglib/heap.c clones of dglHeapInsertMax are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/dglib/heap.c  dglHeapInsertMin
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/dglib/heap.c clones of dglHeapInsertMin are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/dglib/heap.c  dglHeapInsertMax
          File :grass/trunk/lib/vector/dglib/sp-template.c
          Function
DGL_SP_CACHE_DISTANCE_FUNC(Begins at: 57, Ends at:86)
ParamNBR:     |       5 |     * |      WARNING |         5 |
LOC:          |      30 |       |           OK |        30 |
DGL_SP_CACHE_INITIALIZE_FUNC(Begins at: 29, Ends at:45)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      17 |       |           OK |        17 |
DGL_SP_CACHE_RELEASE_FUNC(Begins at: 47, Ends at:54)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
DGL_SP_CACHE_REPORT_FUNC(Begins at: 88, Ends at:214)
Complexity:   |      18 |    ** | BABY-MONSTER |        18 |
CalledNBR:    |      32 |    ** | BABY-MONSTER |        32 |
LOC:          |     127 |    ** | BABY-MONSTER |       127 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
DGL_SP_DIJKSTRA_FUNC(Begins at: 298, Ends at:585)
Complexity:   |      37 |   *** |      MONSTER |        37 |
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |      52 |   *** |      MONSTER |        52 |
LOC:          |     288 |   *** |      MONSTER |       288 |
Conclusion:   | this function is a       MONSTER           |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Fri Feb 27 09:34:22 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
