[GRASS-QA] GRASS QA: neteler |column.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Jan 2 15:54:42 EST 2009
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/lib/db/dbmi_base/column.c
          Function
db_free_column(Begins at: 374, Ends at:378)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       5 |       |           OK |         5 |
Conclusion:   | this function is a            OK           |
metrics are OK
db_get_column_default_value(Begins at: 33, Ends at:36)
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
db_get_column_description(Begins at: 364, Ends at:367)
CalledNBR:    |       1 |       |           OK |         1 |
metrics are OK
db_get_column_host_type(Begins at: 110, Ends at:113)
metrics are OK
db_get_column_length(Begins at: 240, Ends at:243)
metrics are OK
db_get_column_name(Begins at: 344, Ends at:347)
metrics are OK
db_get_column_precision(Begins at: 84, Ends at:87)
metrics are OK
db_get_column_scale(Begins at: 64, Ends at:67)
metrics are OK
db_get_column_select_priv(Begins at: 280, Ends at:283)
metrics are OK
db_get_column_sqltype(Begins at: 105, Ends at:108)
metrics are OK
db_get_column_update_priv(Begins at: 310, Ends at:313)
metrics are OK
db_get_column_value(Begins at: 23, Ends at:26)
metrics are OK
db_get_table_column(Begins at: 11, Ends at:16)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       2 |       |           OK |         2 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
db_init_column(Begins at: 320, Ends at:327)
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
db_set_column_description(Begins at: 354, Ends at:357)
metrics are OK
db_set_column_has_defined_default_value(Begins at: 120, Ends at:123)
metrics are OK
db_set_column_has_undefined_default_value(Begins at: 130, Ends at:133)
metrics are OK
db_set_column_host_type(Begins at: 54, Ends at:57)
metrics are OK
db_set_column_length(Begins at: 250, Ends at:253)
metrics are OK
db_set_column_name(Begins at: 334, Ends at:337)
metrics are OK
db_set_column_null_allowed(Begins at: 210, Ends at:213)
metrics are OK
db_set_column_precision(Begins at: 94, Ends at:97)
metrics are OK
db_set_column_scale(Begins at: 74, Ends at:77)
metrics are OK
db_set_column_select_priv_granted(Begins at: 260, Ends at:263)
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Fri Jan 02 16:11:22 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
