[GRASS-QA] GRASS QA: hcho |add_3dface.c add_arc.c add_circle.c add_line.c ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Mon Jan 5 12:36:40 EST 2009
Hello hcho,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/vector/v.in.dxf/add_3dface.c
          Function
add_3dface(Begins at: 5, Ends at:124)
              |          New Metrics           |Old Metrics|
Complexity:   |      25 |   *** |      MONSTER |        25 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      21 |     * |      WARNING |        21 |
LOC:          |     120 |    ** | BABY-MONSTER |       120 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/vector/v.in.dxf/add_arc.c
          Function
add_arc(Begins at: 5, Ends at:85)
Complexity:   |      16 |    ** | BABY-MONSTER |        16 |
CalledNBR:    |      15 |     * |      WARNING |        15 |
LOC:          |      81 |     * |      WARNING |        81 |
Conclusion:   | this function is a  BABY-MONSTER           |
Clone analysis:
          File :grass/trunk/vector/v.in.dxf/add_circle.c
          Function
add_circle(Begins at: 5, Ends at:71)
Complexity:   |      14 |    ** | BABY-MONSTER |        14 |
CalledNBR:    |      13 |     * |      WARNING |        13 |
LOC:          |      67 |     * |      WARNING |        67 |
Clone analysis:
          File :grass/trunk/vector/v.in.dxf/add_line.c
          Function
add_line(Begins at: 5, Ends at:85)
Complexity:   |      18 |    ** | BABY-MONSTER |        18 |
CalledNBR:    |      14 |     * |      WARNING |        14 |
Clone analysis:
          File :grass/trunk/vector/v.in.dxf/add_lwpolyline.c
          Function
add_lwpolyline(Begins at: 5, Ends at:113)
Complexity:   |      20 |    ** | BABY-MONSTER |        20 |
CalledNBR:    |      19 |     * |      WARNING |        19 |
LOC:          |     109 |    ** | BABY-MONSTER |       109 |
Clone analysis:
          File :grass/trunk/vector/v.in.dxf/add_point.c
          Function
add_point(Begins at: 5, Ends at:68)
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      64 |     * |      WARNING |        64 |
Clone analysis:
          File :grass/trunk/vector/v.in.dxf/add_polyline.c
          Function
add_polyline(Begins at: 7, Ends at:252)
Complexity:   |      44 |   *** |      MONSTER |        44 |
CalledNBR:    |      39 |   *** |      MONSTER |        39 |
LOC:          |     246 |   *** |      MONSTER |       246 |
write_pnts(Begins at: 254, Ends at:288)
Complexity:   |       6 |     * |      WARNING |         6 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      35 |       |           OK |        35 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
          File :grass/trunk/vector/v.in.dxf/add_text.c
          Function
add_text(Begins at: 5, Ends at:119)
LOC:          |     115 |    ** | BABY-MONSTER |       115 |
Clone analysis:
          File :grass/trunk/vector/v.in.dxf/dxf_to_vect.c
          Function
check_ext(Begins at: 154, Ends at:170)
Complexity:   |       7 |     * |      WARNING |         7 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      17 |       |           OK |        17 |
dxf_to_vect(Begins at: 15, Ends at:152)
Complexity:   |      37 |   *** |      MONSTER |        37 |
CalledNBR:    |      47 |   *** |      MONSTER |        47 |
LOC:          |     138 |    ** | BABY-MONSTER |       138 |
make_head(Begins at: 181, Ends at:201)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       1 |       |           OK |         1 |
LOC:          |      21 |       |           OK |        21 |
 at least 1 values are close to an outlier please consider revising code!
set_entity(Begins at: 172, Ends at:179)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       8 |       |           OK |         8 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Mon Jan 05 12:53:55 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
