[GRASS-QA] GRASS QA: glynn |draw2.c | 12 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Jan 9 16:19:56 EST 2009
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/display/draw2.c
          Class
plane(Begins at: 22, Ends at:25)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
rectangle(Begins at: 9, Ends at:15)
          Class
vector(Begins at: 17, Ends at:20)
          Function
D_box(Begins at: 894, Ends at:906)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       4 |       |           OK |         4 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      13 |       |           OK |        13 |
Conclusion:   | this function is a            OK           |
metrics are OK
D_box_clip(Begins at: 827, Ends at:836)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
D_clip_to_display(Begins at: 289, Ends at:293)
ParamNBR:     |       1 |     * |      WARNING |         1 |
CalledNBR:    |       5 |     * |      WARNING |         5 |
LOC:          |       5 |       |           OK |         5 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
D_clip_to_map(Begins at: 323, Ends at:327)
CalledNBR:    |       5 |       |           OK |         5 |
 at least 1 values are close to an outlier please consider revising code!
D_clip_to_screen(Begins at: 305, Ends at:311)
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       7 |       |           OK |         7 |
D_cont(Begins at: 846, Ends at:852)
ParamNBR:     |       2 |     * |      WARNING |         2 |
CalledNBR:    |       3 |       |           OK |         3 |
D_cont_abs(Begins at: 865, Ends at:868)
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
D_cont_abs_clip(Begins at: 466, Ends at:479)
Complexity:   |       2 |       |           OK |         2 |
LOC:          |      14 |     * |      WARNING |        14 |
D_cont_clip(Begins at: 442, Ends at:458)
LOC:          |      17 |     * |      WARNING |        17 |
D_line(Begins at: 854, Ends at:858)
ParamNBR:     |       4 |     * |      WARNING |         4 |
D_line_abs(Begins at: 870, Ends at:874)
D_line_abs_clip(Begins at: 481, Ends at:485)
Complexity:   |       1 |     * |      WARNING |         1 |
D_line_clip(Begins at: 460, Ends at:464)
D_line_width(Begins at: 908, Ends at:911)
CalledNBR:    |       0 |       |           OK |         0 |
D_move(Begins at: 838, Ends at:844)
ParamNBR:     |       2 |    ** | BABY-MONSTER |         2 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
D_move_abs(Begins at: 860, Ends at:863)
D_move_abs_clip(Begins at: 345, Ends at:349)
D_move_clip(Begins at: 339, Ends at:343)
D_polydots(Begins at: 876, Ends at:880)
ParamNBR:     |       3 |       |           OK |         3 |
metrics are OK
D_polydots_clip(Begins at: 487, Ends at:517)
Complexity:   |       6 |       |           OK |         6 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      31 |       |           OK |        31 |
metrics are OK
D_polygon(Begins at: 888, Ends at:892)
metrics are OK
D_polygon_clip(Begins at: 783, Ends at:792)
metrics are OK
D_polygon_cull(Begins at: 703, Ends at:712)
metrics are OK
D_polyline(Begins at: 882, Ends at:886)
metrics are OK
D_polyline_clip(Begins at: 615, Ends at:627)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
D_polyline_cull(Begins at: 593, Ends at:605)
Complexity:   |       4 |     * |      WARNING |         4 |
D_set_clip(Begins at: 264, Ends at:277)
LOC:          |      14 |       |           OK |        14 |
alloc_dst(Begins at: 47, Ends at:56)
alloc_src(Begins at: 58, Ends at:67)
box_clip(Begins at: 794, Ends at:810)
CalledNBR:    |      13 |       |           OK |        13 |
LOC:          |      17 |       |           OK |        17 |
box_clip_ll(Begins at: 812, Ends at:825)
clip_plane(Begins at: 119, Ends at:155)
LOC:          |      37 |       |           OK |        37 |
clip_polygon_plane(Begins at: 714, Ends at:752)
LOC:          |      39 |       |           OK |        39 |
coerce(Begins at: 192, Ends at:198)
cull_polygon_plane(Begins at: 629, Ends at:672)
LOC:          |      44 |       |           OK |        44 |
cull_polyline_plane(Begins at: 519, Ends at:562)
dealloc_src(Begins at: 69, Ends at:83)
LOC:          |      15 |       |           OK |        15 |
dist_plane(Begins at: 109, Ends at:112)
CalledNBR:    |       0 |     * |      WARNING |         0 |
do_clip(Begins at: 157, Ends at:180)
Complexity:   |       9 |       |           OK |         9 |
CalledNBR:    |       4 |     * |      WARNING |         4 |
LOC:          |      24 |       |           OK |        24 |
do_convert(Begins at: 85, Ends at:107)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      23 |       |           OK |        23 |
do_ll_wrap(Begins at: 231, Ends at:250)
ParamNBR:     |       7 |     * |      WARNING |         7 |
CalledNBR:    |       2 |     * |      WARNING |         2 |
LOC:          |      20 |       |           OK |        20 |
euclidify(Begins at: 200, Ends at:229)
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      30 |       |           OK |        30 |
metrics are OK
interpolate(Begins at: 114, Ends at:117)
metrics are OK
line_clip(Begins at: 366, Ends at:390)
LOC:          |      25 |       |           OK |        25 |
metrics are OK
line_clip_abs(Begins at: 416, Ends at:440)
metrics are OK
line_clip_ll(Begins at: 392, Ends at:414)
polygon_clip(Begins at: 754, Ends at:781)
CalledNBR:    |      11 |       |           OK |        11 |
LOC:          |      28 |       |           OK |        28 |
polygon_cull(Begins at: 674, Ends at:701)
metrics are OK
polyline_clip(Begins at: 607, Ends at:613)
metrics are OK
polyline_cull(Begins at: 564, Ends at:591)
metrics are OK
shift_angle(Begins at: 187, Ends at:190)
ParamNBR:     |       1 |       |           OK |         1 |
metrics are OK
shift_count(Begins at: 182, Ends at:185)
Clone analysis:
This file has 12 potentially cloned functions:
  D_polygon_clip  D_polyline_cull  D_polyline_clip  alloc_src  alloc_dst  polyline_cull  polygon_cull  polyline_cull  polygon_clip  polygon_cull  polygon_clip
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of D_polygon_clip are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c  D_polygon_cull
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of D_polygon_cull are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c  D_polygon_clip
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of D_polyline_clip are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c  D_polyline_cull
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of D_polyline_cull are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c  D_polyline_clip
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of alloc_dst are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c  alloc_src
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of alloc_src are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c  alloc_dst
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of polygon_clip are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c  polyline_cull
          /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c  polygon_cull
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of polygon_cull are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c  polygon_clip
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of polyline_cull are:
____________________________________________
Threshold grass key metrics values at Fri Jan 09 16:38:08 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
