[GRASS-QA] GRASS QA: neteler |gsd_img_mpeg.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Mon Jan 19 10:12:05 EST 2009
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/lib/ogsf/gsd_img_mpeg.c
          Function
add_video_stream(Begins at: 55, Ends at:103)
              |          New Metrics           |Old Metrics|
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      49 |     * |      WARNING |        49 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
alloc_picture(Begins at: 115, Ends at:138)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      24 |       |           OK |        24 |
 at least 1 values are close to an outlier please consider revising code!
close_video(Begins at: 264, Ends at:274)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       2 |       |           OK |         2 |
LOC:          |      11 |       |           OK |        11 |
Conclusion:   | this function is a            OK           |
metrics are OK
gsd_close_mpeg(Begins at: 422, Ends at:451)
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      30 |       |           OK |        30 |
metrics are OK
gsd_init_mpeg(Begins at: 286, Ends at:366)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |      27 |    ** | BABY-MONSTER |        27 |
LOC:          |      81 |     * |      WARNING |        81 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
gsd_write_mpegframe(Begins at: 375, Ends at:415)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      41 |       |           OK |        41 |
metrics are OK
open_video(Begins at: 146, Ends at:196)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |      13 |     * |      WARNING |        13 |
LOC:          |      51 |     * |      WARNING |        51 |
 at least 3 values are close to an outlier please consider revising code!
write_video_frame(Begins at: 204, Ends at:256)
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      53 |     * |      WARNING |        53 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Mon Jan 19 10:32:23 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
