[GRASS-QA] GRASS QA: martinl |main.c | 4 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Jul 8 11:59:52 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/db/db.execute/main.c
          Function
get_stmt(Begins at: 136, Ends at:163)
              |          New Metrics           |Old Metrics|
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      28 |       |           OK |        28 |
Conclusion:   | this function is a            OK           |
metrics are OK
main(Begins at: 37, Ends at:91)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |      25 |    ** | BABY-MONSTER |        25 |
LOC:          |      55 |     * |      WARNING |        55 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
parse_command_line(Begins at: 94, Ends at:133)
CalledNBR:    |      15 |     * |      WARNING |        15 |
LOC:          |      40 |       |           OK |        40 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
stmt_is_empty(Begins at: 166, Ends at:171)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
  main  parse_command_line  parse_command_line
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.execute/main.c clones of main are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/execute.c  main
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.execute/execute.c  main
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.execute/main.c clones of parse_command_line are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/execute.c  parse_command_line
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.execute/execute.c  parse_command_line
____________________________________________
Threshold grass key metrics values at Wed Jul 08 11:44:29 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
