[GRASS-QA] GRASS QA: hamish |main.c N_gradient_calc.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Jun 4 23:29:54 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/display/d.nviz/main.c
          Function
do_profile(Begins at: 333, Ends at:405)
              |          New Metrics           |Old Metrics|
Complexity:   |      10 |       |           OK |        10 |
ParamNBR:     |       7 |       |           OK |         7 |
CalledNBR:    |      29 |       |           OK |        29 |
LOC:          |      73 |       |           OK |        73 |
Conclusion:   | this function is a            OK           |
metrics are OK
main(Begins at: 43, Ends at:326)
Complexity:   |      22 |   *** |      MONSTER |        22 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     125 |   *** |      MONSTER |       125 |
LOC:          |     284 |   *** |      MONSTER |       284 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
read_rast(Begins at: 413, Ends at:517)
Complexity:   |      15 |       |           OK |        15 |
ParamNBR:     |       6 |       |           OK |         6 |
CalledNBR:    |      24 |       |           OK |        24 |
LOC:          |     105 |       |           OK |       105 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/lib/gpde/N_gradient_calc.c
          Function
N_calc_gradient_field_2d_stats(Begins at: 29, Ends at:57)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      29 |       |           OK |        29 |
metrics are OK
N_calc_gradient_field_3d_stats(Begins at: 300, Ends at:333)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      34 |       |           OK |        34 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
N_compute_gradient_field_2d(Begins at: 105, Ends at:202)
Complexity:   |      14 |    ** | BABY-MONSTER |        14 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      27 |    ** | BABY-MONSTER |        27 |
LOC:          |      98 |    ** | BABY-MONSTER |        98 |
Conclusion:   | this function is a  BABY-MONSTER           |
N_compute_gradient_field_3d(Begins at: 386, Ends at:534)
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |      41 |   *** |      MONSTER |        41 |
LOC:          |     149 |   *** |      MONSTER |       149 |
N_compute_gradient_field_components_2d(Begins at: 242, Ends at:290)
Complexity:   |       9 |     * |      WARNING |         9 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      49 |     * |      WARNING |        49 |
 at least 3 values are close to an outlier please consider revising code!
N_compute_gradient_field_components_3d(Begins at: 578, Ends at:640)
Complexity:   |      13 |    ** | BABY-MONSTER |        13 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      10 |     * |      WARNING |        10 |
LOC:          |      63 |     * |      WARNING |        63 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Jun 04 23:27:20 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
