[GRASS-QA] GRASS QA: glynn |main.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Jun 30 12:32:44 EDT 2009
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/general/g.parser/main.c
          Class
context(Begins at: 36, Ends at:46)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Function
main(Begins at: 258, Ends at:421)
              |          New Metrics           |Old Metrics|
Complexity:   |      21 |   *** |      MONSTER |        21 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      42 |   *** |      MONSTER |        42 |
LOC:          |     164 |   *** |      MONSTER |       164 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
parse_boolean(Begins at: 171, Ends at:183)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      13 |       |           OK |        13 |
Conclusion:   | this function is a            OK           |
metrics are OK
parse_flag(Begins at: 118, Ends at:153)
Complexity:   |       7 |     * |      WARNING |         7 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      14 |     * |      WARNING |        14 |
LOC:          |      36 |       |           OK |        36 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
parse_module(Begins at: 89, Ends at:116)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      28 |       |           OK |        28 |
 at least 2 values are close to an outlier please consider revising code!
parse_option(Begins at: 185, Ends at:256)
Complexity:   |      14 |    ** | BABY-MONSTER |        14 |
CalledNBR:    |      30 |    ** | BABY-MONSTER |        30 |
LOC:          |      72 |     * |      WARNING |        72 |
Conclusion:   | this function is a  BABY-MONSTER           |
parse_toplevel(Begins at: 62, Ends at:87)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      26 |       |           OK |        26 |
 at least 1 values are close to an outlier please consider revising code!
parse_type(Begins at: 155, Ends at:169)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      15 |       |           OK |        15 |
metrics are OK
translate(Begins at: 52, Ends at:60)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
LOC:          |       9 |       |           OK |         9 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Jun 30 12:20:35 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
