[GRASS-QA] GRASS QA: martinl |main.c main.c main.c main.c ...| no
	clones | 0 monsters |0 warnings
    soccerlab.info at gmail.com
    Tue Jun 30 17:04:22 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/imagery/i.albedo/main.c
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/imagery/i.biomass/main.c
          File :grass/trunk/imagery/i.eb.soilheatflux/main.c
          File :grass/trunk/imagery/i.evapo.time_integration/main.c
          File :grass/trunk/imagery/i.modis.qc/main.c
          File :grass/trunk/imagery/i.vi/main.c
          File :grass/trunk/imagery/i.vpoints/colors.c
          Function
cursor_color(Begins at: 82, Ends at:101)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      20 |       |           OK |        20 |
Conclusion:   | this function is a            OK           |
metrics are OK
done(Begins at: 232, Ends at:235)
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
get_vector_color(Begins at: 182, Ends at:199)
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      18 |       |           OK |        18 |
metrics are OK
set_blue(Begins at: 103, Ends at:107)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       5 |       |           OK |         5 |
metrics are OK
set_colors(Begins at: 22, Ends at:25)
metrics are OK
set_cur_clr(Begins at: 139, Ends at:179)
Complexity:   |       8 |     * |      WARNING |         8 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      41 |       |           OK |        41 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
set_gray(Begins at: 109, Ends at:113)
metrics are OK
set_green(Begins at: 115, Ends at:119)
metrics are OK
set_menu_colors(Begins at: 28, Ends at:78)
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |      51 |     * |      WARNING |        51 |
 at least 2 values are close to an outlier please consider revising code!
set_red(Begins at: 121, Ends at:125)
metrics are OK
set_white(Begins at: 127, Ends at:131)
metrics are OK
set_yellow(Begins at: 133, Ends at:137)
metrics are OK
setmap_blue(Begins at: 201, Ends at:204)
metrics are OK
setmap_gray(Begins at: 206, Ends at:209)
metrics are OK
setmap_green(Begins at: 211, Ends at:214)
metrics are OK
setmap_red(Begins at: 216, Ends at:219)
metrics are OK
setmap_white(Begins at: 221, Ends at:224)
metrics are OK
setmap_yellow(Begins at: 226, Ends at:229)
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/include/raster.h
          File :grass/trunk/lib/g3d/g3dcolor.c
          Function
G3d_readColors(Begins at: 46, Ends at:99)
Complexity:   |      10 |     * |      WARNING |        10 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
LOC:          |      54 |     * |      WARNING |        54 |
 at least 4 values are close to an outlier please consider revising code!
G3d_removeColor(Begins at: 20, Ends at:42)
Complexity:   |       2 |       |           OK |         2 |
LOC:          |      23 |       |           OK |        23 |
metrics are OK
G3d_writeColors(Begins at: 363, Ends at:408)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |      15 |     * |      WARNING |        15 |
LOC:          |      46 |     * |      WARNING |        46 |
read_colors(Begins at: 101, Ends at:132)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
LOC:          |      32 |       |           OK |        32 |
read_new_colors(Begins at: 146, Ends at:289)
Complexity:   |      39 |   *** |      MONSTER |        39 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      25 |    ** | BABY-MONSTER |        25 |
LOC:          |     144 |   *** |      MONSTER |       144 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
read_old_colors(Begins at: 291, Ends at:359)
Complexity:   |      13 |    ** | BABY-MONSTER |        13 |
LOC:          |      69 |     * |      WARNING |        69 |
Conclusion:   | this function is a  BABY-MONSTER           |
Clone analysis:
          File :grass/trunk/lib/raster/color_hist.c
          File :grass/trunk/lib/raster/color_init.c
          File :grass/trunk/lib/raster/color_insrt.c
          File :grass/trunk/lib/raster/color_rand.c
          File :grass/trunk/lib/raster/color_read.c
          File :grass/trunk/lib/raster/color_rule.c
          File :grass/trunk/lib/raster/color_rules.c
          File :grass/trunk/lib/raster/color_set.c
          File :grass/trunk/lib/raster/color_write.c
          File :grass/trunk/lib/raster/color_xform.c
          File :grass/trunk/lib/rst/interp_float/output2d.c
          Function
IL_output_2d(Begins at: 28, Ends at:654)
Complexity:   |      88 |   *** |      MONSTER |        88 |
ParamNBR:     |      18 |   *** |      MONSTER |        18 |
CalledNBR:    |     184 |   *** |      MONSTER |       184 |
LOC:          |     627 |   *** |      MONSTER |       627 |
Clone analysis:
          File :grass/trunk/lib/rst/interp_float/resout2d.c
          Function
IL_resample_output_2d(Begins at: 27, Ends at:546)
Complexity:   |      78 |   *** |      MONSTER |        78 |
CalledNBR:    |     151 |   *** |      MONSTER |       151 |
LOC:          |     520 |   *** |      MONSTER |       520 |
Clone analysis:
          File :grass/trunk/ps/ps.map/main.c
          Function
main(Begins at: 88, Ends at:753)
Complexity:   |     102 |   *** |      MONSTER |       102 |
CalledNBR:    |     220 |   *** |      MONSTER |       220 |
LOC:          |     666 |   *** |      MONSTER |       666 |
Clone analysis:
          File :grass/trunk/raster/r.composite/main.c
          Class
band(Begins at: 25, Ends at:39)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Function
main(Begins at: 49, Ends at:267)
Complexity:   |      22 |   *** |      MONSTER |        22 |
CalledNBR:    |      71 |   *** |      MONSTER |        71 |
LOC:          |     219 |   *** |      MONSTER |       219 |
make_color_cube(Begins at: 275, Ends at:306)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       6 |       |           OK |         6 |
metrics are OK
quantize(Begins at: 269, Ends at:273)
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.flow/io.c
          Function
close_files(Begins at: 173, Ends at:187)
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      15 |       |           OK |        15 |
metrics are OK
open_existing_cell_file(Begins at: 58, Ends at:69)
LOC:          |      12 |       |           OK |        12 |
metrics are OK
open_output_files(Begins at: 156, Ends at:171)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      16 |       |           OK |        16 |
open_segment_file(Begins at: 128, Ends at:154)
Complexity:   |       6 |     * |      WARNING |         6 |
LOC:          |      27 |       |           OK |        27 |
 at least 3 values are close to an outlier please consider revising code!
read_input_files(Begins at: 71, Ends at:126)
Complexity:   |      14 |    ** | BABY-MONSTER |        14 |
CalledNBR:    |      26 |    ** | BABY-MONSTER |        26 |
LOC:          |      56 |     * |      WARNING |        56 |
tmp_name(Begins at: 41, Ends at:54)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      14 |       |           OK |        14 |
metrics are OK
write_density_file(Begins at: 189, Ends at:226)
CalledNBR:    |      23 |    ** | BABY-MONSTER |        23 |
LOC:          |      38 |       |           OK |        38 |
Clone analysis:
          File :grass/trunk/raster/r.lake/main.c
          Function
is_near_water(Begins at: 85, Ends at:100)
metrics are OK
load_window_values(Begins at: 103, Ends at:130)
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
LOC:          |      28 |       |           OK |        28 |
main(Begins at: 132, Ends at:393)
Complexity:   |      37 |   *** |      MONSTER |        37 |
CalledNBR:    |     103 |   *** |      MONSTER |       103 |
LOC:          |     262 |   *** |      MONSTER |       262 |
save_map(Begins at: 42, Ends at:82)
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       9 |   *** |      MONSTER |         9 |
CalledNBR:    |      12 |     * |      WARNING |        12 |
Clone analysis:
          File :grass/trunk/raster/r.param.scale/write_cols.c
          Function
write_cols(Begins at: 19, Ends at:36)
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.random/support.c
          Function
make_support(Begins at: 6, Ends at:73)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      68 |     * |      WARNING |        68 |
Clone analysis:
          File :grass/trunk/raster/r.random.surface/save.c
          Function
SaveMap(Begins at: 8, Ends at:219)
CalledNBR:    |      34 |    ** | BABY-MONSTER |        34 |
LOC:          |     212 |   *** |      MONSTER |       212 |
Clone analysis:
          File :grass/trunk/raster/r.slope.aspect/main.c
          Function
main(Begins at: 60, Ends at:1389)
Complexity:   |     157 |   *** |      MONSTER |       157 |
CalledNBR:    |     499 |   *** |      MONSTER |       499 |
LOC:          |    1330 |   *** |      MONSTER |      1330 |
Clone analysis:
          File :grass/trunk/raster/r.watershed/ram/close_maps.c
          Function
close_maps(Begins at: 7, Ends at:257)
Complexity:   |      47 |   *** |      MONSTER |        47 |
CalledNBR:    |     100 |   *** |      MONSTER |       100 |
LOC:          |     251 |   *** |      MONSTER |       251 |
Clone analysis:
          File :grass/trunk/raster/r.watershed/seg/close_maps.c
          Function
close_maps(Begins at: 5, Ends at:198)
Complexity:   |      32 |   *** |      MONSTER |        32 |
CalledNBR:    |      72 |   *** |      MONSTER |        72 |
LOC:          |     194 |   *** |      MONSTER |       194 |
Clone analysis:
          File :grass/trunk/raster/simwe/simlib/output.c
          Function
output_data(Begins at: 14, Ends at:600)
Complexity:   |      79 |   *** |      MONSTER |        79 |
CalledNBR:    |     180 |   *** |      MONSTER |       180 |
LOC:          |     587 |   *** |      MONSTER |       587 |
output_et(Begins at: 603, Ends at:755)
Complexity:   |      20 |    ** | BABY-MONSTER |        20 |
ParamNBR:     |       0 |       |           OK |         0 |
CalledNBR:    |      36 |    ** | BABY-MONSTER |        36 |
LOC:          |     153 |   *** |      MONSTER |       153 |
Clone analysis:
          File :grass/trunk/swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c
          Function
r_slope_aspect(Begins at: 60, Ends at:1418)
Complexity:   |     159 |   *** |      MONSTER |       159 |
CalledNBR:    |     511 |   *** |      MONSTER |       511 |
LOC:          |    1359 |   *** |      MONSTER |      1359 |
Clone analysis:
          File :grass/trunk/vector/v.to.rast/support.c
          Class
My_color_rule(Begins at: 104, Ends at:111)
          Class
My_labels_rule(Begins at: 253, Ends at:258)
          Function
update_cats(Begins at: 72, Ends at:84)
LOC:          |      13 |       |           OK |        13 |
metrics are OK
update_colors(Begins at: 42, Ends at:54)
metrics are OK
update_dbcolors(Begins at: 86, Ends at:230)
Complexity:   |      12 |     * |      WARNING |        12 |
CalledNBR:    |      38 |   *** |      MONSTER |        38 |
LOC:          |     145 |   *** |      MONSTER |       145 |
update_fcolors(Begins at: 57, Ends at:69)
metrics are OK
update_hist(Begins at: 17, Ends at:39)
update_labels(Begins at: 234, Ends at:501)
Complexity:   |      35 |   *** |      MONSTER |        35 |
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |      97 |   *** |      MONSTER |        97 |
LOC:          |     268 |   *** |      MONSTER |       268 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Jun 30 16:52:09 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
