[GRASS-QA] GRASS QA: mmetz |select.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Mar 4 10:57:24 EST 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/lib/vector/Vlib/select.c
          Function
Vect_select_areas_by_box(Begins at: 91, Ends at:115)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      25 |       |           OK |        25 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Vect_select_areas_by_polygon(Begins at: 293, Ends at:351)
Complexity:   |      10 |     * |      WARNING |        10 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      18 |     * |      WARNING |        18 |
LOC:          |      59 |     * |      WARNING |        59 |
 at least 4 values are close to an outlier please consider revising code!
Vect_select_isles_by_box(Begins at: 130, Ends at:147)
Complexity:   |       2 |       |           OK |         2 |
LOC:          |      18 |       |           OK |        18 |
Vect_select_lines_by_box(Begins at: 37, Ends at:77)
Complexity:   |       6 |     * |      WARNING |         6 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      41 |       |           OK |        41 |
 at least 2 values are close to an outlier please consider revising code!
Vect_select_lines_by_polygon(Begins at: 197, Ends at:274)
Complexity:   |      14 |    ** | BABY-MONSTER |        14 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |      15 |     * |      WARNING |        15 |
LOC:          |      78 |     * |      WARNING |        78 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Vect_select_nodes_by_box(Begins at: 158, Ends at:181)
LOC:          |      24 |       |           OK |        24 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Mar 04 11:02:44 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
