[GRASS-QA] GRASS QA: hamish |local_proto.h main.c support.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Mar 4 12:48:10 EST 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/imagery/i.pca/local_proto.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/branches/develbranch_6/imagery/i.pca/main.c
          Function
calc_covariance(Begins at: 276, Ends at:343)
              |          New Metrics           |Old Metrics|
Complexity:   |      12 |     * |      WARNING |        12 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      33 |    ** | BABY-MONSTER |        33 |
LOC:          |      68 |     * |      WARNING |        68 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
calc_mu(Begins at: 225, Ends at:273)
Complexity:   |       9 |     * |      WARNING |         9 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      49 |     * |      WARNING |        49 |
Conclusion:   | this function is a       WARNING           |
 at least 4 values are close to an outlier please consider revising code!
dump_eigen(Begins at: 532, Ends at:549)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      18 |       |           OK |        18 |
 at least 1 values are close to an outlier please consider revising code!
main(Begins at: 45, Ends at:176)
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      57 |   *** |      MONSTER |        57 |
LOC:          |     132 |    ** | BABY-MONSTER |       132 |
Conclusion:   | this function is a       MONSTER           |
round_c(Begins at: 179, Ends at:191)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      13 |       |           OK |        13 |
Conclusion:   | this function is a            OK           |
metrics are OK
set_output_scale(Begins at: 194, Ends at:222)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      29 |       |           OK |        29 |
write_pca(Begins at: 346, Ends at:528)
Complexity:   |      28 |   *** |      MONSTER |        28 |
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |      52 |   *** |      MONSTER |        52 |
LOC:          |     183 |   *** |      MONSTER |       183 |
Clone analysis:
This file does not contain cloned functions
          File :grass/branches/develbranch_6/imagery/i.pca/support.c
          Function
write_history(Begins at: 33, Ends at:69)
CalledNBR:    |      12 |     * |      WARNING |        12 |
LOC:          |      37 |       |           OK |        37 |
 at least 2 values are close to an outlier please consider revising code!
write_support(Begins at: 10, Ends at:30)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |      10 |     * |      WARNING |        10 |
LOC:          |      21 |       |           OK |        21 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Wed Mar 04 12:53:30 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
