[GRASS-QA] GRASS QA: martinl |nviz.h digit.cpp driver.h driver_draw.cpp ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sat Mar 7 20:09:29 EST 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/gui/wxpython/nviz/nviz.h
          Class
Nviz(Begins at: 29, Ends at:95)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |     39 |      0 |    741 |
|OLD Metrics |      1 |      0 |      0 |     39 |      0 |    741 |
Clone analysis:
This file does not contain cloned functions
          File :grass/branches/develbranch_6/gui/wxpython/vdigit/digit.cpp
          Class
Digit(Begins at: -9999, Ends at:-9999)
|NEW Metrics |      1 |      0 |      5 |      9 |      0 |      3 |
|OLD Metrics |      1 |      0 |      5 |      9 |      0 |      3 |
          Method
Digit(Begins at: 25, Ends at:38)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      14 |       |           OK |        14 |
Conclusion:   | this function is a            OK           |
metrics are OK
UpdateSettings(Begins at: 57, Ends at:62)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
~Digit(Begins at: 45, Ends at:50)
ParamNBR:     |       0 |       |           OK |         0 |
CalledNBR:    |       2 |       |           OK |         2 |
metrics are OK
Clone analysis:
          File :grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h
          Class
DisplayDriver(Begins at: 32, Ends at:216)
|NEW Metrics |      1 |      0 |      0 |     33 |      0 |    528 |
|OLD Metrics |      1 |      0 |      0 |     33 |      0 |    528 |
          Class
_region(Begins at: 69, Ends at:83)
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
_settings(Begins at: 90, Ends at:115)
          Class
_topology(Begins at: 117, Ends at:135)
          Class
symbol(Begins at: 85, Ends at:88)
Clone analysis:
          File :grass/branches/develbranch_6/gui/wxpython/vdigit/driver_draw.cpp
The system don't find class, method and function
 in this file during analysis!
          File :grass/branches/develbranch_6/gui/wxpython/vdigit/message.cpp
____________________________________________
Threshold grass key metrics values at Sat Mar 07 20:15:27 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
