[GRASS-QA] GRASS QA: mmetz |geom.c global.h main.c main.c ...| 3 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Mar 10 10:04:10 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/vector/v.in.ogr/geom.c
          Function
centroid(Begins at: 30, Ends at:157)
              |          New Metrics           |Old Metrics|
Complexity:   |      18 |    ** | BABY-MONSTER |        18 |
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |      42 |   *** |      MONSTER |        42 |
LOC:          |     128 |    ** | BABY-MONSTER |       128 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
geom(Begins at: 160, Ends at:351)
Complexity:   |      28 |   *** |      MONSTER |        28 |
CalledNBR:    |      73 |   *** |      MONSTER |        73 |
LOC:          |     192 |   *** |      MONSTER |       192 |
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/vector/v.in.ogr/global.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/vector/v.in.ogr/main.c
          Function
main(Begins at: 47, Ends at:1133)
Complexity:   |     115 |   *** |      MONSTER |       115 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     422 |   *** |      MONSTER |       422 |
LOC:          |    1087 |   *** |      MONSTER |      1087 |
Clone analysis:
          File :grass/trunk/vector/v.net.iso/main.c
          Function
main(Begins at: 44, Ends at:538)
Complexity:   |      58 |   *** |      MONSTER |        58 |
CalledNBR:    |     139 |   *** |      MONSTER |       139 |
LOC:          |     495 |   *** |      MONSTER |       495 |
Clone analysis:
          File :grass/trunk/vector/v.net.salesman/main.c
          Function
add_city(Begins at: 49, Ends at:70)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      22 |       |           OK |        22 |
Conclusion:   | this function is a            OK           |
metrics are OK
cmp(Begins at: 391, Ends at:403)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      13 |       |           OK |        13 |
metrics are OK
cnode(Begins at: 44, Ends at:47)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
main(Begins at: 73, Ends at:389)
Complexity:   |      39 |   *** |      MONSTER |        39 |
CalledNBR:    |     122 |   *** |      MONSTER |       122 |
LOC:          |     317 |   *** |      MONSTER |       317 |
Clone analysis:
This file has 3 potentially cloned functions:
  cmp  cmp
In /var/project-manager/grass/grassSVN/grass/trunk/vector/v.net.salesman/main.c clones of cmp are:
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.lrs/v.lrs.label/main.c  cmp_along
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.net.path/path.c  cmp
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.net.steiner/main.c  cmp
____________________________________________
Threshold grass key metrics values at Tue Mar 10 09:10:34 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
