[GRASS-QA] GRASS QA: mmetz |poly.c build_nat.c map.c open.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Mar 17 09:36:06 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/vector/diglib/poly.c
          Function
dig_find_area_poly(Begins at: 93, Ends at:116)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      24 |       |           OK |        24 |
Conclusion:   | this function is a            OK           |
metrics are OK
dig_get_poly_points(Begins at: 34, Ends at:86)
Complexity:   |       7 |     * |      WARNING |         7 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      53 |     * |      WARNING |        53 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/lib/vector/Vlib/build_nat.c
          Function
Vect_attach_centroids(Begins at: 332, Ends at:413)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      82 |     * |      WARNING |        82 |
 at least 2 values are close to an outlier please consider revising code!
Vect_attach_isle(Begins at: 261, Ends at:288)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      28 |       |           OK |        28 |
metrics are OK
Vect_attach_isles(Begins at: 298, Ends at:322)
LOC:          |      25 |       |           OK |        25 |
metrics are OK
Vect_build_line_area(Begins at: 40, Ends at:118)
Complexity:   |      10 |     * |      WARNING |        10 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      26 |    ** | BABY-MONSTER |        26 |
LOC:          |      79 |     * |      WARNING |        79 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Vect_build_nat(Begins at: 425, Ends at:677)
Complexity:   |      42 |   *** |      MONSTER |        42 |
CalledNBR:    |      59 |   *** |      MONSTER |        59 |
LOC:          |     253 |   *** |      MONSTER |       253 |
Conclusion:   | this function is a       MONSTER           |
Vect_isle_find_area(Begins at: 129, Ends at:251)
Complexity:   |      11 |     * |      WARNING |        11 |
CalledNBR:    |      27 |    ** | BABY-MONSTER |        27 |
LOC:          |     123 |    ** | BABY-MONSTER |       123 |
Clone analysis:
          File :grass/trunk/lib/vector/Vlib/map.c
          Function
Vect_copy(Begins at: 156, Ends at:285)
Complexity:   |      15 |     * |      WARNING |        15 |
ParamNBR:     |       4 |       |           OK |         4 |
CalledNBR:    |      60 |       |           OK |        60 |
LOC:          |     130 |       |           OK |       130 |
 at least 1 values are close to an outlier please consider revising code!
Vect_copy_map_lines(Begins at: 44, Ends at:99)
Complexity:   |      10 |    ** | BABY-MONSTER |        10 |
ParamNBR:     |       2 |     * |      WARNING |         2 |
CalledNBR:    |      20 |   *** |      MONSTER |        20 |
LOC:          |      56 |    ** | BABY-MONSTER |        56 |
Vect_copy_table(Begins at: 644, Ends at:650)
Complexity:   |       1 |     * |      WARNING |         1 |
ParamNBR:     |       6 |       |           OK |         6 |
CalledNBR:    |       1 |     * |      WARNING |         1 |
LOC:          |       7 |     * |      WARNING |         7 |
Vect_copy_table_by_cats(Begins at: 667, Ends at:720)
Complexity:   |       6 |       |           OK |         6 |
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |      13 |       |           OK |        13 |
LOC:          |      54 |       |           OK |        54 |
Vect_copy_tables(Begins at: 567, Ends at:629)
CalledNBR:    |      22 |     * |      WARNING |        22 |
LOC:          |      63 |     * |      WARNING |        63 |
 at least 4 values are close to an outlier please consider revising code!
Vect_delete(Begins at: 430, Ends at:553)
Complexity:   |      16 |     * |      WARNING |        16 |
ParamNBR:     |       1 |    ** | BABY-MONSTER |         1 |
CalledNBR:    |      62 |     * |      WARNING |        62 |
LOC:          |     124 |     * |      WARNING |       124 |
Vect_rename(Begins at: 302, Ends at:420)
Complexity:   |      14 |    ** | BABY-MONSTER |        14 |
ParamNBR:     |       3 |       |           OK |         3 |
CalledNBR:    |      50 |   *** |      MONSTER |        50 |
LOC:          |     119 |    ** | BABY-MONSTER |       119 |
Vect_set_category_index_update(Begins at: 746, Ends at:749)
Complexity:   |       1 |    ** | BABY-MONSTER |         1 |
ParamNBR:     |       1 |     * |      WARNING |         1 |
CalledNBR:    |       0 |   *** |      MONSTER |         0 |
LOC:          |       4 |    ** | BABY-MONSTER |         4 |
Vect_set_release_support(Begins at: 731, Ends at:734)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
copy_file(Begins at: 110, Ends at:141)
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      32 |       |           OK |        32 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/vector/Vlib/open.c
          Function
Vect__open_old(Begins at: 124, Ends at:396)
Complexity:   |      31 |       |           OK |        31 |
ParamNBR:     |       5 |       |           OK |         5 |
CalledNBR:    |     102 |       |           OK |       102 |
LOC:          |     273 |       |           OK |       273 |
metrics are OK
Vect_coor_info(Begins at: 608, Ends at:646)
Complexity:   |       6 |   *** |      MONSTER |         6 |
CalledNBR:    |      11 |   *** |      MONSTER |        11 |
LOC:          |      39 |   *** |      MONSTER |        39 |
Vect_maptype_info(Begins at: 656, Ends at:673)
Complexity:   |       5 |     * |      WARNING |         5 |
CalledNBR:    |       4 |     * |      WARNING |         4 |
LOC:          |      18 |       |           OK |        18 |
Vect_open_new(Begins at: 514, Ends at:597)
Complexity:   |       8 |       |           OK |         8 |
CalledNBR:    |      43 |       |           OK |        43 |
LOC:          |      84 |       |           OK |        84 |
metrics are OK
Vect_open_old(Begins at: 410, Ends at:413)
CalledNBR:    |       1 |   *** |      MONSTER |         1 |
LOC:          |       4 |     * |      WARNING |         4 |
Vect_open_old_head(Begins at: 464, Ends at:468)
LOC:          |       5 |       |           OK |         5 |
Vect_open_spatial_index(Begins at: 767, Ends at:832)
LOC:          |      66 |       |           OK |        66 |
Vect_open_topo(Begins at: 686, Ends at:757)
Complexity:   |       7 |       |           OK |         7 |
CalledNBR:    |      16 |       |           OK |        16 |
LOC:          |      72 |     * |      WARNING |        72 |
Vect_open_update(Begins at: 427, Ends at:449)
Complexity:   |       2 |     * |      WARNING |         2 |
CalledNBR:    |       2 |     * |      WARNING |         2 |
LOC:          |      23 |     * |      WARNING |        23 |
Vect_open_update_head(Begins at: 482, Ends at:502)
LOC:          |      21 |       |           OK |        21 |
Vect_set_open_level(Begins at: 96, Ends at:107)
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      12 |       |           OK |        12 |
fatal_error(Begins at: 59, Ends at:71)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      13 |       |           OK |        13 |
metrics are OK
format(Begins at: 38, Ends at:42)
ParamNBR:     |       0 |       |           OK |         0 |
metrics are OK
open_old_dummy(Begins at: 32, Ends at:35)
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Mar 17 08:44:12 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
